Evo IX SE FRONT LIP INSTALL
Hey guys im swapping the standard lip on my evo 9 for the SE version. I have been told that there is two side brackets I would need. My question is, is there any other way to install the lip without the brackets or are the brackets a must have to get the lip on there???
i installed my se lip fine. i did it a couple weeks ago and i had no problem without any brackets. there is about 1-1.5 inch gap from the lip to the underpanel. so i just took some zip ties to make sure it is not dragging hope that helps
If you are NOT using an under panel, you'll be fine without the 3 black ABS panels. If you ARE running an under panel, wether it's OEM, or Aftermarket, it's a smart idea to buy the 3 'SE' Lip panels because with that gap, you are creating unwanted turbulence. You want your undercarriage to be as 'free-flow' and aerodynamic as possible. Plus, now your under panel is just hanging lower (with, or without zip-ties), etc. and there's a good chance when going over a speed bump, or a driveway curb you're going to hit the under panel.
I also went from a standard IX lip to an 'SE' Lip.
For anyone else looking for the Airdam reinforcement pieces.
Their are 2 identically mirrored pieces on each side, those PN's are:
(I don't know which is left/right, sorry)
6512A151
6512A152
Then there is one piece on the passenger side that "completes" the lip
6400B288
6512A151
6512A152
6400B288
FS[West]: Evo 9 GG Se Lip
maxroach
Apr 6, 2017 11:17 AM
FS[South]: BNIB Evo 9 SE lip
not_nyce06
Feb 6, 2017 01:17 PM
Teal2nnr
Jan 31, 2016 07:26 PM
