BOV staling out car
Old Nov 24, 2003 | 09:29 PM
Kr1's Avatar
Kr1
BOV staling out car
I just installed a Turbo XS RFL. The car runs great intill I down shift it feels like it wants to cut off. Does anyone have this problem, and if so how to fix it.
Old Nov 24, 2003 | 09:30 PM
BadBoyBeltran's Avatar
VTA or Recirc? You might have the openings switched.
Old Nov 24, 2003 | 09:33 PM
Kr1's Avatar
Kr1
VTA
Old Nov 24, 2003 | 09:37 PM
hel_if_ino's Avatar
something you will have to deal with... typically you would just loosen up the set screw allowing the bov to bypass to the intake, but since yours is vta theres no use, you will just have to deal with it.
Old Nov 24, 2003 | 09:40 PM
d EVOlved OnE's Avatar
Remove VTA and install DV (or recirc whichever you prefer).
Old Nov 24, 2003 | 09:41 PM
Just learn how to shift with it. Have the spring set on the softest setting and kinda "ride on the engine while slowing down" before putting it in neutral.
I know VTA is bad, but man,... whoooooooooooooooooooooooooooooosh!
Old Nov 25, 2003 | 03:09 PM
Jev3gs's Avatar
Get a Forge Div Valve. I haven't had a single issue yet with mine, and others are getting good results also.
Old Jan 10, 2004 | 11:09 AM
EvAsian's Avatar
Exclamation Same Problem...
I just got the same blow off valve recently and i've been having the same problem with my engine just dying on me. I wish i could find a way to really fix it, but all i've gotten is that i just have to cope with it! If any one knows a better BOV please let me know, or if you there is a way i can fix it w/o my engine dying on me please let me know! It's an over all great BOV but i just hate the fact that it's messing up my idling!!!
_____________________________________-
I find out a way to fix it! The blow off valve comes with 6 washers which you can add to the BOV. Well since i was desperate to fix it i went and i bought 4 more washers. I first put 2 in and no air was escaping the valve, but it wasnt getting the right sound out of it. Later i took out one more washers and now it's perfect! NO MORE LOW RPMS WHICH CAUSE MY ENGINE TO DIE! My reccomendation is to put 7 washers in. I fixed my problem, maybe it'll fix yours. Good Luck.
Old Jan 11, 2004 | 06:58 PM
johnnyevo's Avatar
solution: put the stock one back in
Old Jan 14, 2004 | 10:45 PM
Tsi's Avatar
Tsi
mistu never desgined ANY of its turbo cars to be able to vent the bov. the mas air usually freaks and does funky things to the fuel map to compensate.
put the stock one back on, or buy a 1g bov kit from buschar and recirc it like it is ment to be
Old Jan 31, 2004 | 12:17 PM
GotBoost25psi's Avatar
hey i installed the RFL and the only time it acts like its going to stall is when i punch it hit about 6500 rpm and push the clutch in and let it go to idle it drops about 300 rpm under idle but thats all, and ive never ever had any prblms shifting up or down with it!!! i only have 2 washers in, maybe try that set up? i also have/had videos on timzcat's ftp, i cant find them so i will upload them agean if you want to watch them!! btw yes i am vta, any ?'s just pm me! cya
Old Jan 31, 2004 | 05:13 PM
Grod101's Avatar
you guys need to understand how the MAS works and what VTA does when you still have a MAS.....
- Your air is being measured by the MAS before the BOV... when you VTA you are loosing air that was already measured and the ECU has already calculated and offset how much fuel is needed... when you VTA you are taking that much less air in but you are suppling the same amount of fuel that the ECU told it too with the amount of air the MAS read... so what happens is you run pig rich at that point and end up stalling.....
the only way to fix the problem your having is put in a stand alone like the AEM.... or put in a DV like the stock or a greddy or forge....
hope this helps you out
Old Mar 24, 2004 | 12:03 PM
ok, ive had my VTA on for 3 months now and ive only stalled once!!!! maybe my car is special or your not doing something right???? btw my only mod is bov and intake filter
Old Mar 24, 2004 | 04:17 PM
forum04pl's Avatar
i work for a shop and we deal through turbo xs alot. they have been telling us not to order the type h rfl's because they are having problems like you have stated with them. they are working to fix it but using the normal type h is reccomended. trust me the regular type h is loud.
Old Mar 27, 2004 | 07:09 AM
EVO8 WHOA's Avatar
from what i was told and understand i guess the only way we can run the VTA bovs is if you get a new ECU that runs off of a Map Bar sensor instead of the Mass Air Flow sensor, so if u wanted to spend the $1600 for an AEM to make yur woosh loud without stalling plus be able to change just about every charachteristic of tuning in the world, do it, i am but its just a number of reasons on top of each other to make me want to go with a Stand Alone
