How to Remove Fender?
Old Jan 1, 2011 | 12:48 PM
terfer's Avatar
I searched and a lot of the threads are unanswered or the links are too and are broken. If anyone can chime in, that'd be great. Also images would even be better! Thanks.
Old Jan 1, 2011 | 01:56 PM
cheez_it33's Avatar
I'm interested in this as well! I plan on doing Dave's FenderMod. Any info would help!
Old Jan 1, 2011 | 06:06 PM
4RETECH's Avatar
Remove tire, remove inner fender liner,remove front bumper.Remove corner plastic trim(one screw behind that).
Also screw holding headlight tab to fender
Either remove front of rocker or entire rocker(i have done both)
two screws at rocker, one screw at door hinge area. upper fender screws.
one screw near headlight housing under bumper trim(you will see it after you remove the front bumper cover.
Old Jan 3, 2011 | 02:44 AM
terfer's Avatar
Thanks! How do I get to the one in the door hinge area? The two 8mm behind the rocker panel are being very stubborn for me. I only have those still on and the one in the hinge area.
Old Jan 3, 2011 | 12:30 PM
4RETECH's Avatar
Did you remove the rocker?? BTW they are 10mm.
The hidge area one I used a 10mm with a universal, 1/4 drive with extension
SmurfZilla
Aug 16, 2015 03:50 PM
hiner005
12
Jun 28, 2014 11:32 AM
kpt6
Mar 21, 2014 05:12 PM
rcantu
Mar 15, 2014 12:23 AM
