Need help selecting correct Spacers
I simply want the flush look for my stock bbs wheels on my evo 8. I use to own an acura rsx and was running spacers on those. The problem with spacers on the acura was that anything less then 20 mm i believe, the stock studs wont clear the spacers.
Is it the same for the evo??
I was told back then that anything less then 20mm , that i had to either get shorter studs to clear the spacer/wheels, cut it, or run spacers without their own studs and use extended studs.
Tried searching but couldnt find anything.
Also remembered something about how some wheel hubs have holes in the back of them that will clear the factory studs?
