Carbon Fiber Engine Plug Cover Install?
Old Feb 2, 2004 | 10:48 PM
neonsalamander's Avatar
For anyone with a CF engine cover, how hard was it to install?
Do the screws that set it in place have to be adjusted to a certain torque? (I'm a newb on modding)
Old Feb 3, 2004 | 09:48 AM
EvoBob82's Avatar
No torque specs just throw her on and tighten it down... Probably the simplest "mod" you can do on the Evo.
Old Feb 3, 2004 | 09:56 AM
en1gma19's Avatar
screw off....screw on...simple as that.......special torque..for the plug cover ......don't make things more difficult than they need to be
Old Feb 3, 2004 | 05:15 PM
If I wanted to swap engine covers, would I have to remove some of the wiring that goes over it?
Old Feb 3, 2004 | 05:51 PM
Fireball's Avatar
It's called a 10mm socket.
Old Feb 3, 2004 | 09:09 PM
Just curious, has anyone on these forums actually gotten a CF engine cover?
Old Feb 3, 2004 | 09:15 PM
rubelcon's Avatar
Yes, I have one. It took me 2 minutes to instal, and it looks very clean. I cant imagine puting the stock plug cover back on now
Old Feb 3, 2004 | 09:34 PM
mifesto's Avatar
wonder if the heat will distort the CB
Would you happen to have any pics?
Old Feb 4, 2004 | 06:25 AM
rubelcon's Avatar
I'll get some for you today..
Old Feb 4, 2004 | 11:40 AM
Dan0119's Avatar
Are you talking about a valve cover or a spark plug wire cover? Here is my RMR spark plug wire cover.
Attached Thumbnails Carbon Fiber Engine Plug Cover Install?-small-underhood-2.jpg
Old Feb 4, 2004 | 12:31 PM
Looks nice Dan, thnx for the pic.
Did you have to detatch the wire that goes over the cover to install it?
Old Feb 4, 2004 | 12:43 PM
rubelcon's Avatar
Thanks dan!!
Old Feb 4, 2004 | 12:52 PM
keviin's Avatar
i have one too... but mine didn't fit right had to dremel the holes to make it fit... it still only took 10 minutes..to install
Old Feb 4, 2004 | 03:12 PM
Dan0119's Avatar
Nah, just move it out of the way. Seriously, it is jost losen the stock bolts, take stock cover off, put new cover on, tighten bolts.
