Brakes shuddering after installing extended studs
Old Jul 28, 2024 | 07:22 PM
Connor Dacey's Avatar
Question Brakes shuddering after installing extended studs
Hi guys,
I've run into a strange issue with my brakes. I've just installed extended wheel studs, and when I went for a drive, I had almost no brake pressure and the brakes were shuddering. Put the car up on jackstands and took all the rims off and can replicate it in the air. No play on the wheel bearings, and have tested with new axle hubs - same problem. Brake pads and rotors are ~3,000kms old, so bedded in all good. No DTCs, ABS light isn't on...
Video of brake pedal:
Video of the ABS pump (while pumping the brakes):
Any help is appreciated!
ColeVo
Apr 20, 2020 09:16 PM
bnr34rb26dett
Feb 14, 2016 09:01 AM
sna08
16
Dec 8, 2011 06:13 PM
dL_EVO
Jul 26, 2006 04:50 PM
EvilBlueEvo8
Nov 14, 2005 07:18 PM
