Whats the best way to lift an evo
I have rhino ramps at home and I'm almost ready to change out the tranny fluids, but I need to somehow figure out how to raise the rear of the car to make it level with the front of the car as its on the rhino ramps. Suggestions?
Originally Posted by psionic98
jack and jack stands... jack it up, place one stand near each tire.. or buy 2 more ramps and jack it up and rest it on the ramps..
. I looked under the car to see better jacking points. I finally found a solid metal frame near the middle of the vehicle. From then on, I use that as my jacking point. As far as I know, it is not damaging anything. Just something to think about...
Originally Posted by oguratevo
There is a jacking point under the front crossmember and use the rear differential to jack the rear up.
... you can use the pinchweld as shown in the manual with a regular hydrolic lift. Just use a block of wood to ditribute the weight along the weld. i lift my car like this every time and my welds are still straight and stock. Think my wood is 12" long... seems to do the trick.
Sorry, had to
. As far as Rhino ramps go, I'm pretty sure it says on the instructions that you should not use 4 of them to lift the car. I'm sure it will probably be OK but if it drops on your head then you won't be able to sue them
. As has already been said, use the 2 jacking points at the front & rear. There are some jack stands that have little bits of frubber on them with a V cut in it so you can place those at the 4 'normal' jacking points to keep it lifted. You might even be able to buy the rubber things for your current jack stands.
