greddy profec b spec 2 installtion?
Old May 31, 2004 | 07:16 PM
htsai14752's Avatar
i remember seeing a lot of walk throughs on the boost controller for the evo before. but now i cant find anymore. i was wondering if anyone can try to find a link to a post with a step by step intructions to installing the boost controller with pictures. thanks
Old May 31, 2004 | 07:31 PM
Quickshift's Avatar
Connet the COM line from the solinoid to the actuator of the wastegate and the NO line to the bottom of the turbo compressor unit. Must remove air box or airfilter unit for easier access. Leave the old stock boost solinoid connected to the harness and just set it aside, cause removing it will cause a CEL or SES to come on.
Old May 31, 2004 | 07:35 PM
Quickshift's Avatar
Just look under the intake box, you will notice a little unit with 3 small vaccum hoses coming off it. Follow the lines that run to the turbo. There will be a tee in the line. One end is going up to the wastegate actuator and the other to the bottom of the turbo ( a nipple is coming of the piping) . You just connect the lines from the solinoid to the turbo the way I said in my above post.
Old Jun 1, 2004 | 08:27 AM
LancerEvoMR's Avatar
Moving to Evo HT / Requests / Questions.
Old Jul 22, 2004 | 02:35 PM
sleet's Avatar
Any pictures of this ? Also what size are the bolts to remove the air-box?
soeuroithurts
Jul 30, 2016 10:53 PM
Tommy_Lee
Aug 16, 2010 01:34 PM
Evojj25
Jul 13, 2009 02:38 PM
tim85851
12
Jul 14, 2008 11:33 AM
tobz
Jul 26, 2006 05:31 PM
