vishnu exhaust
Old Aug 18, 2004 | 09:45 AM
4G63 Racer's Avatar
vishnu exhaust
Has anyone put on the vishnu standard exhaust, I just got it and want to know if any problems arise.
Old Aug 18, 2004 | 10:20 AM
ruzs's Avatar
I have. It comes with a rubber hanger that I did not install. I don't know where it goes. The install is straight forward, but messy beacuse of the undercoating that gets everywhere. The exhaust is VERY close to the center axle mount and the cat is VERY close to the heat shield. Mine rattles at idle so I will have to look at it soon. Overall it is not so hard. You have to remove the under pan which has a lot of plastic screws. The bolts to the O2 housing are fairly tight. Good luck. let me know if you have more questions.
Old Aug 18, 2004 | 10:31 AM
David@Vishnu's Avatar
Originally Posted by ruzs
I have. It comes with a rubber hanger that I did not install. I don't know where it goes. The install is straight forward, but messy because of the undercoating that gets everywhere. The exhaust is VERY close to the center axle mount and the cat is VERY close to the heat shield. Mine rattles at idle so I will have to look at it soon. Overall it is not so hard. You have to remove the under pan which has a lot of plastic screws. The bolts to the O2 housing are fairly tight. Good luck. let me know if you have more questions.
Guys wd40 the hangars loosen the two springbolts at the O2 housing to DB juncture and grap the exhaust tip and give it a wiggle to set the exhaust at the most neutral point and retighten the bolts.
Old Aug 18, 2004 | 10:47 AM
LancerEvoMR's Avatar
Moving to Evo H/T Questions.
Old Aug 18, 2004 | 11:22 AM
raymerd's Avatar
Had this problem, got this advice from David on Monday did the stuff ... woot, no worries. Works like a champ.
I love mine, got some good comments last night at the NTEC meeting.
-- dave
Old Aug 18, 2004 | 10:55 PM
4G63 Racer's Avatar
Thanks yall I'll let you know how it goes
VtexGt3
Apr 19, 2005 04:03 PM
alby988
Jan 27, 2005 07:27 AM
zane11
Aug 19, 2004 01:54 PM
ReHeat
Oct 7, 2003 06:13 PM
SzuChenEvo
Jul 11, 2003 02:41 PM
