How-to Perrin 25mm rear swaybar & stout mounts
I searched and could not find a how-to on installing the Perrin 25mm swaybar / sway bar so I decided to help others out with one of my own.
How-to install Perrin 25mm swaybar & stout mounts. 1. Remove the nuts holding the stock rear swaybar to the endlinks. 2. Remove the passenger-side rear wheel and then wiggle the top rubber muffler mount off of the hangar as seen below. http://www.robertcasipit.com/albums/...how2.sized.jpg 3. Remove the bolt holding the muffler up at the rear rubber muffler mount as seen below. http://www.robertcasipit.com/albums/...how2.sized.jpg 4. Now remove the 2 bolts holding the 3rd rubber muffler mount to the chassis as seen below. This will allow you to lower the exhaust system low enough for the stock bar to be removed. http://www.robertcasipit.com/albums/...how2.sized.jpg 5. Now remove the 4 bolts keeping the OEM stock bar connected to the car's frame and then wiggle the bar out starting with the muffler side. 6. Once the OEM bar is out, installation is simply reverse of above. Do not forget to lube the rubber bushing that came with the Perrin bar. http://www.robertcasipit.com/albums/..._018.sized.jpg http://www.robertcasipit.com/albums/..._010.sized.jpg |
WOW!!! That is a nice swaybar. It appears to be easy to install.
Very nice write up with pictures,the most detailed I've seen so far.
savaho,
the holes one the ends of the bars are to increase or decrease the tension inflicted on the bar. furthest out is the softest setting and furthest in is the stiffest. 100% guarantee |
Originally Posted by iWant2play
(Post 3844295)
savaho,
the holes one the ends of the bars are to increase or decrease the tension inflicted on the bar. furthest out is the softest setting and furthest in is the stiffest. 100% guarantee Thanks for that information. It would've been nice if Perrin put that in the directions. |
can you get those mounts seperate?
Originally Posted by EvilBlueEvo8
(Post 3902711)
Does the perrin sway bar have any clearence issue with any exhausts?
how does it feel around town or at the track
That looks so much better than the Hotchkis Mount... Perhaps I'm off, but it looks like it is more rigid. I had the Hotchkis on my VIII and did like it a lot on the stiffest setting. anyone else have thoughts on this?
Nice write up. Just put my on about 2 weeks ago.
love perrin
How-to install Perrin 25mm swaybar & stout mounts. 1. Remove the nuts holding the stock rear swaybar to the endlinks. 2. Remove the passenger-side rear wheel and then wiggle the top rubber muffler mount off of the hangar as seen below. http://www.socalevo.net/gallery/albu...ounts%2001.jpg 3. Remove the bolt holding the muffler up at the rear rubber muffler mount as seen below. http://www.socalevo.net/gallery/albu...ounts%2002.jpg 4. Now remove the 2 bolts holding the 3rd rubber muffler mount to the chassis as seen below. This will allow you to lower the exhaust system low enough for the stock bar to be removed. http://www.socalevo.net/gallery/albu...ounts%2003.jpg 5. Now remove the 4 bolts keeping the OEM stock bar connected to the car's frame and then wiggle the bar out starting with the muffler side. 6. Once the OEM bar is out, installation is simply reverse of above. Do not forget to lube the rubber bushing that came with the Perrin bar. http://www.socalevo.net/gallery/albu...ounts%2004.jpg http://www.socalevo.net/gallery/albu...ounts%2005.jpg from: https://www.evolutionm.net/forums/sh...d.php?t=245204 |
Thanka for this info....I am trying to decide on which rear bar to get - I really like the Perrin setup vs. the Cusco........this was a very helpful post
...what other bars did you consider and where did you get yours? $? Thanks - Sick Speed |
Are you using the Perrin end links or the OEM?
