| EVO8speed |
Apr 3, 2007 11:18 AM |
Need "How To" for HID's and OEM Fog lights for RS models
Need “How to” for installing HID’s with fog lights (the ones in the headlight assembly) using OEM Headlight assembly (which had for HID’s). This would be a conversion for people with RS models. I would assume that that the headlight assembly came with the proper projector for HID’s. And that the installing issues would revolve around the transferring of a used headlight adjustment gear with the wiring (the equipment that makes the light go up or down), the fog light wiring with the OEM button inside the **** pit, and either the use of an OEM or in most case the use of an aftermarket HID kit (Blast and Bulb). I know that the HIDexpert.com has some good kits for this application however, i need to know about the wiring for the fogs and hiegth adjustment wiring equipment. Thanks!
