Need "How To" for HID's and OEM Fog lights for RS models
Old Apr 3, 2007 | 11:18 AM
EVO8speed's Avatar
Need “How to” for installing HID’s with fog lights (the ones in the headlight assembly) using OEM Headlight assembly (which had for HID’s). This would be a conversion for people with RS models. I would assume that that the headlight assembly came with the proper projector for HID’s. And that the installing issues would revolve around the transferring of a used headlight adjustment gear with the wiring (the equipment that makes the light go up or down), the fog light wiring with the OEM button inside the **** pit, and either the use of an OEM or in most case the use of an aftermarket HID kit (Blast and Bulb). I know that the HIDexpert.com has some good kits for this application however, i need to know about the wiring for the fogs and hiegth adjustment wiring equipment. Thanks!
Old Jun 22, 2007 | 10:43 AM
joey0480's Avatar
bump
