apg oil catch can
Old Jun 21, 2007 | 10:38 AM
rastamike's Avatar
agp oil catch can
i recently installed agp catch can, after two weeks i found a very small amount of oil in the accumulator.the problem is a oil return line is rubbing against the can which will create a hole soon. agp says it should fit without any modification ,i dont see how.any one have the same problem? thanks Rasta.2006 IX
Old Jun 21, 2007 | 11:15 AM
Pd1's Avatar
Pd1
I don't understand how you've got the return line rubbing against the can itself. Post a pic of this, please, and we may be able to help.
I'm using this can now with no trouble, though I did have to tweak an A/C line or two to give plenty of clearance.
Old Jun 21, 2007 | 01:34 PM
rastamike's Avatar
agp can
the line in queston is below the high pressure a/c line,i was afraid to bend it.i will try to make a bracket and attach to shock tower.dont know how to post pic yet.thanks
Old Jun 22, 2007 | 04:13 PM
Pd1's Avatar
Pd1
Ah yes....A/C line is very different from an "oil return line."
Just bend it a hair out of the way and snug the catch can bracket down while pulling the assembly away from the A/C lines and you'll be fine.
EvolvedAK
Oct 10, 2014 04:22 PM
Ming8
May 13, 2012 03:44 AM
anthonyrb98
12
Apr 9, 2012 09:34 AM
REVOlution86
Jan 14, 2009 10:15 AM
