aem wideband HELP!!!
Old Oct 2, 2007 | 07:26 PM
1 WICKED EVO's Avatar
where do u hook the white and blue wire, the white says to a 0-5 volt. can u hook the blue up to the serialport under the dash?so it will work with evoscan.
Old Oct 2, 2007 | 07:58 PM
Usedcarfinders's Avatar
you hook it up to your laptop, through an adapter, not the serial port
Old Oct 2, 2007 | 08:11 PM
56Hotrod's Avatar
The white is 0-5 volt for external EMS support. The blue wire is for RS232 serial port, but you need to purchase a serial port connector (9 pin), where the blue wire connects to pin 2, and you have to hook up a ground to pin 5. The 9 pin RS232 connector's pin arrangement is as follows:
top = 1,2,3,4,5
btm = 6,7,8,9
You can pick up on from radio shack for $17
http://www.radioshack.com/product/in...entPage=search
Cut one end off, and test continuity for pin 2 and pin 5 to get the right wires, connect the blue AEM wire to pin 2, and ground pin 5. Connect to laptop's serial port and log with hyperterminal.
Old Oct 3, 2007 | 02:51 PM
thanks
