need help with water hoses!!
Old Feb 28, 2008 | 01:06 PM
downshift411's Avatar
ok, behind the block theirs 2 water hoses and on my car(mirage 99 evo swapped) the radiator tubing on the fire wall sits side by side horizontal. not sure if the fire wall tubes are the same with evo 7-9. i connected the left tube with the hose connecting to the tube nearest the waterpump. the right tube on the firewall connected lower under the intake manifold(heater hose). is this right or should it be the other way around? i had this setup before but i had one of my hoses burst. well i wanna know if i put the hoses wrong or i might need upgraded rear radiator hoses.
if you dont know what im tryin to say then... you suck...in general, which water hose goes to which firewall tube specifically. only the water hoses that goes to the fire wall. its a water hose and heater hose which goes to which.
need this ASAP! thanx.
Old Feb 28, 2008 | 01:31 PM
help bump
Old Feb 28, 2008 | 11:35 PM
Jameson_IXMR's Avatar
What engine is in your car? Not all 4g63's are created equal. What type of water pump is attached? Which hoses are you talking about? The radiator or the ones in back? Do they go to your intake manifold? Be specific please and we can help you out.
Old Mar 1, 2008 | 09:37 PM
heater hoses that routes to the fire wall??
