Radiator Problem
Old Jul 16, 2008 | 10:15 AM
BootScraper88's Avatar
Radiator Problem
Ok guys heres the deal , Im putting my new gt3076 turbo setup into my evo and I just bought a slim line fan and I went to put my radiator in and it does not want to go in all the way. Do u guys have any reasons why this would be Thanks
Old Jul 16, 2008 | 08:22 PM
one1fastevo8's Avatar
3076 install
I installed my 3076R and had the same problem but I did not take out the radiator. I have a DME tubular manifold 3076R turbo with a .70 A/R and the 4 bolt downpipe (which sucks) external tail wastegate. The turbo will hit the radiator. Reinstall your radiator. What I did was put the turbo in first then the manifold then the wastegate. do not tighten the bolts at this time. Put them in loosely. Take a piece of rubber (like the factory rubber boost hose). I also had extra rubber from my hard pipe install. See if anybody has an extra hose laying around. Cut a 2x2inch square put it between the radiator and the intake side of the turbo (which would be the only thing touching the radiator). It will put a little presure on the radiator but it will be fine. I did mine 2 months ago and it is fin and good working order. Or you could just go and buy a CBRD racing radiator. But I did not have the $500 for the radiator after spending $2000 on the set up. As my stock turbo was shot and having everything apart I had to continue with the install. Hope this helps.
Old Jul 17, 2008 | 07:29 AM
thanks a lot i will try that out
Ekoy
May 20, 2015 01:18 PM
Czarcasm
Jun 21, 2013 11:18 PM
Carrier
Jan 30, 2012 09:26 AM
MR. EVO MR
16
May 14, 2010 01:11 AM
190hpkilla
Oct 13, 2009 03:32 AM
