My Cars Shaking Under Boost!
Old Nov 15, 2008 | 11:33 PM
mr_4g63's Avatar
Question My Cars Shaking Under Boost!
CAN ANYONE ENLIGHTEN ME A PROBLEM HAS ARISEN IN MY RUNNING GEAR....
wHEN I PUT MY FOOT DOWN AND BRING ON BOOST BETWEEN 5PSI - 28PSI I GET A WOBBLING VIBRATION, FEELS SIMILAR TO A SEPARATED TYRE WHICH ITS NOT BECAUSE I DEPRESS THE CLUTCH AND IT GOES AWAY...
I'M SUSPECTING THE LAST TIME I DROVE IT I DIDN'T TAKE MY FOOT OF THE CLUTCH PROPERLY WHEN GIVING IT *******S AND HEATED UP MY EVER SO LIGHTENED FLYWHEEL AND WARPED IT..
OR I'VE BENT A HALF SHAFT OR DAMAGED A CONSTANT VELOCITY JOINT
ANY SUGGESTIONS WOULD BE APPRECIATED
Old Nov 19, 2008 | 04:34 PM
AdvanRG2's Avatar
Sounds expensive. Good luck. My guess is your flywheel.
Old Nov 22, 2008 | 11:06 PM
akauf's Avatar
Stop yelling at me!!!
Sounds like your on the right track, slipping clutch / warped flywheel theory. Care to add any more details on the symptom and why you believe they're related?
Also search is your friend.
GL
Old Nov 23, 2008 | 12:06 AM
P-ROY's Avatar
did you put locktite on the flywheel bolts?
Old Nov 16, 2010 | 10:34 PM
VETDRMS's Avatar
CAPS are not the best way to express yourself.
A damaged drive shaft can cause a huge amount of vibration.
Old Nov 16, 2010 | 11:10 PM
azinterrider's Avatar
Any knock from the motor?
1Ferrari
14
Feb 5, 2012 09:40 AM
scrivs
Apr 20, 2011 03:06 PM
clubEVO93
Oct 18, 2010 02:01 PM
BURNALL_4
Jul 31, 2007 08:30 PM
EvoDan2004
Apr 5, 2007 05:47 PM
