AEM uego w/b install??????
Old Apr 15, 2009 | 04:30 AM
4g634life's Avatar
ive been searching for this for a day and havent found it
Anyone know how to install the AEM uego wideband?????
Old Apr 15, 2009 | 04:57 AM
cush87's Avatar
The easiest way that I found was to tie the gauge power into the power wire for you head unit. To run the wide band sensor itself.
Go in the passengers side of you car, on the front of you center consoul underneath the dash there is a plastic piece that pops off.
Take that piece off.
Then pull back the carpet. There is a rubber grommet you can pull out, that's located on the hump in the floor. To get the sensor through the hole you may need to enlarge the hole a little bit, I had to on my car.
Old Apr 16, 2009 | 05:33 PM
Maximum404's Avatar
Veteran: Navy
For those that are interested, on a IX this hole is on the driver's side.
Old Apr 16, 2009 | 05:48 PM
Mr. Evo IX's Avatar
Here you go.. also the grommet that were talking about is under the passenger seat in IX's. It's where the factory rear o2 sensor wiring is. Going under the driver side of the car would require your wires to cross the driveshaft.
https://www.evolutionm.net/forums/ec...uctions-1.html
JakeTheVIII
Jun 20, 2016 02:57 PM
REV.olution
May 18, 2015 08:50 AM
franc01
Apr 12, 2015 06:24 AM
12WWGSR91
Dec 20, 2014 10:08 AM
Jasoob
Apr 20, 2011 02:04 PM
