Best way to prep a valve cover for paint?
Old Jun 9, 2010 | 08:19 PM
a_awdgsx's Avatar
Hey i just got a valve cover to replaced my cracked one, and the paint is old on the one i just bought. What is the best way to clean/sand for paint? What grit sandpaper should be used? Should i spray parts cleaner on it at all to take off oil? Thanks
Old Jun 10, 2010 | 09:18 PM
white_evo27's Avatar
Originally Posted by a_awdgsx
hey i just got a valve cover to replaced my cracked one, and the paint is old on the one i just bought. What is the best way to clean/sand for paint? What grit sandpaper should be used? Should i spray parts cleaner on it at all to take off oil? Thanks
+1
Old Jun 10, 2010 | 09:38 PM
05evoGSR's Avatar
get a degreaser spray and clean everything up. next wet sand the cover with 180-200 grit until you have the top layer sanded and dull. Clean off and with water and see how things look and if you missed any spots, if not do it all over again with around 250-300 grit to smooth things out. When that is all complete clean the cover again, let dry, hit with 2 coats of primer and 2-3 coats of paint. Let the paint fully cure then put 2 coats of clear, this is how i have painted aluminum in the past and never had a problem. I would recommend dupli-color high heat series for your primer, paint and clear coat.
Old Jun 11, 2010 | 10:09 AM
a_awdgsx's Avatar
thanks man i'll give that a shot!
Old Jun 13, 2010 | 12:02 AM
evolancer04's Avatar
let us know how it turned out
Old Jun 13, 2010 | 02:24 AM
veszett's Avatar
i did pretty much as the above post then took it to a paint shop where they mixed up a colour i liked and came back the next day for it. got them to do the heat shield as well but even tho i did ask for that to be a flat/matte black finish it still looks better than it did.
been on for a couple months now and no sign of damage/flaking/chipping or the like.
Attached Thumbnails Best way to prep a valve cover for paint?-p5020059-copy.jpg
Old Jun 13, 2010 | 07:18 AM
a_awdgsx's Avatar
I think im going to go with wrinkle red, i need to find the clear coat
Old Jun 16, 2010 | 10:53 PM
SRToad4's Avatar
I will be doing mine very soon, maybe this weekend
Old Jun 17, 2010 | 12:38 AM
j03yYunG's Avatar
the blue cover above looks clean.
Old Jun 17, 2010 | 12:49 AM
EvoTsiGuru's Avatar
That looks pretty purple to me, maybe it's just my eyes sorry but cant tell.
Old Jun 17, 2010 | 11:28 PM
veszett's Avatar
yeah its in between...voilet/purple/blue metallic colour thingy...when the blue hoses reflect of it they give it more of a blue look tho.
got it done cause i like the bright colour showing through the vent when the bonnet is closed speshial, hahaa.
Old Jun 28, 2010 | 06:11 PM
fromxtor's Avatar
Powdercoat is the best bet, and will probably be cheaper. Get it bead blasted, wipe clean, coat, bake, done.
Old Jul 22, 2010 | 10:01 AM
EvoGuy5's Avatar
Problem is with sandblasting....you'll never fully clean the small glass bead, or sand particles out of the baffles. That stuff will ruin the top end of the engine. I just popped my cover off this morning and will be prepping and painting the rest of the day...going black. I'll post pics later on
Old Jul 22, 2010 | 10:17 AM
Boltz.'s Avatar
FCOTM Winner
Brake clean and a red scuff pad will do the trick.
Old Jul 25, 2010 | 02:56 PM
ericD's Avatar
i like the blue up top. very nice. gonna hav to try this soon....
