Clock wire pins
Old Sep 22, 2010 | 01:06 AM
evolancer04's Avatar
Clock wire pins
Does anybody know how to get the pins out of the harness on the clock. They are not the same as the ECU pins. I have been messing with it but i dont want to break it since its plastic. I have an HFS-6 that i want to run using my clock but i dont just want to splice in and use electrical tape. I want to be able to pull the pin out so i can heat shrink it after.
Old Sep 22, 2010 | 06:56 AM
noob12's Avatar
Have you thought about using a parallel tap and a snap plug? You use the parallel tap on the main wire and then use the snap plug as a quick disconnect to that plug. No cutting or splicing. If you ever have to remove the plug, there's no bare wire to worry about or have to apply electrical tape on it.
Alchem1st
Mar 15, 2022 08:47 AM
jayt27
Mar 2, 2016 09:50 AM
littlegif1
AEM EMS
Jan 20, 2016 08:41 PM
EvoRSfor060
Dec 25, 2005 06:42 PM
