HELP!.. need to take sunroof cover on GSR off!.. PICSinside
well i ended up putting suede onto my grey interior pieces including headliner. well ive took everything off except the sunroof cover.. cant seem to find how to slide it out or drop it without dropping WHOLE sunroof assembly which is like 30 nuts and bolts
ill post pics up if you guys havent seen it before in a little bit.. not a pretty sight at all
so if anyone has done it or has tips onto removing a sunroof cover on a 03 GSR let me know ASAP.. thanks!
UPDATE: IF YOU CUT THE WHITE CLIP AT THE END OF DRIVERS SIDE RAIL U CAN PULL THE COVER ALL THE WAY BACK WITH A LITTLE FORCE TO CLEAR THE HUMP BY THE VENTS/HANDLE
