93octane to E-85 easy way?
Old Jul 19, 2011 | 03:34 PM
rong.'s Avatar
I am looking for a way to easily drain the tank of 93 so I can fill up with E-85. Does anyone have a easy set up? Petcock on tank? Looking for a easy way to do this so I can use E-85 once in a while and not all the time. I already have a double pumper and other supporting mods for the E 85. Looking for quick solutions.
Old Jul 19, 2011 | 03:44 PM
Piro Fyre's Avatar
Don't the gas tanks have drain bolts?
Old Jul 19, 2011 | 03:51 PM
Ian0611's Avatar
Yeah I've been told that there are two drain bolts on the bottom of the tank
Old Jul 19, 2011 | 03:55 PM
EVO KNVL's Avatar
I just drive until it gets pretty low and then I fill it up with the other. No big deal on the small mixture. The next fill up will make it closer to 100% of that mixture.
Old Jul 19, 2011 | 04:52 PM
RJones's Avatar
There are two drain bolts. One on each side.
Old Jul 19, 2011 | 05:01 PM
Jim in Tucson's Avatar
Use a piece of fuel hose. Pull off the return line and slip on the hose. Start the car and run the motor and let the fuel pump squirt gas into a gas can or your buddy's car.
DO NOT SMOKE DURING THIS PROCEDURE!!!
Old Jul 19, 2011 | 05:12 PM
RazorLab's Avatar
This, it's a billion times easier and faster then the drain bolts.
Old Jul 19, 2011 | 06:46 PM
n2oiroc's Avatar
you need to have a low tank to do it or one side of the saddle tank will still be full.
Old Jul 20, 2011 | 04:25 AM
rong.'s Avatar
Thanks for the replies. I will run it low and do the return line into a gas can. Thanks
Old Jul 20, 2011 | 08:09 AM
TopSpeed's Avatar
LOL! Good advice.
-Josh
Old Jul 25, 2011 | 10:56 PM
boostdd's Avatar
Have to say never thought about when u had to switch between fuels
Old Aug 3, 2011 | 04:49 AM
4ag18psi's Avatar
I just run the car really low on 93 and then fill with e and switch my map and boost never had a problem And do it often
Old Aug 5, 2011 | 08:41 AM
gCASEy200's Avatar
Originally Posted by evo knvl
i just drive until it gets pretty low and then i fill it up with the other. No big deal on the small mixture. The next fill up will make it closer to 100% of that mixture.
+1
Old Aug 5, 2011 | 08:52 AM
4ag18psi's Avatar
did you get it figured out
Old Aug 5, 2011 | 02:31 PM
rong.'s Avatar
still getting worked on
car still getting worked on, actually waiting to get worked on. Then get tuned.
