power steering pump
Old Dec 1, 2011 | 05:20 PM
TJSAP00's Avatar
power steering pump
any how tos on doing a power steering pump on a 2003 8?
Old Dec 1, 2011 | 05:55 PM
dastallion951's Avatar
pretty straight forward man, use a vacuum pump to suck all the fluid out of the reservoir, turn the wheel with the car off one time each way to help push the fluid into the reservoir. Remove serpentine belt, disconnect power steering lines, unbolt pump from bracket, reinstall new one, reinstall lines with new crush washers and bolt it back on, put on your serpentine belt. Top off the fluid to full, turn your car on let it run for a minute, then turn your wheel a few times side to side each end to end. Check your fluid after, make sure its at the full line, then thats pretty much it. Power steering pumps are pretty straight forward install.
Old Dec 2, 2011 | 12:24 PM
TJSAP00's Avatar
sounds pretty straight forward. thank you
asu11
Feb 18, 2017 11:13 AM
Fasturbo
Feb 4, 2017 08:46 AM
pinoy_gm808
Aug 14, 2016 08:23 PM
araz5260
Jun 24, 2016 03:50 PM
192raptor
Nov 1, 2015 02:29 PM
