First clutch job! AARRGGHHH!!!
I have a axle popper tool that I use, they worked excellent to get the cv axles off. A quick tap and they were off. I have seen some guys also just use a pry bar and hammer to tap the axle off.
Im in the process of getting my transmission off. I only seem to have 30 min here or 20 min there to work on it so this might take me a while.
After getting the trans off the transfercase couldnt you just jack the engine up after you get the transmission slid off to give you more room? Im doing this on jackstands as well and it doesnt seem like its really necessary to lower the subframe? Looks like if you just unbolt the dri side motor mount and bracket completely, it should give you plenty of room assuming you have the vehicle jacked up high enough. Unless you guys are talking about the lower front crossmember that holds the front motor mount?
Love reading these threads.. I did a clutch on a Mitsubshi Magna (Transverse FWD).. that wasn't so bad.. but when I did my Legnum (much like an evo, AWD, same drivetrain).. the added AWD complexity adds quite a bit to the job.
The extra pain on the Legnum being a Twin Turbo V6 -- is the rear turbo and most notably hard oil lines get in the way a bit trying to get one of the transfer case bolts off.
Well we finished after 20 some odd hours. Quite a learning experience that built my confidence (somewhat). I reffered to evom numerous times throughout this round of mods. Very helpful!!!
About to do my Evo clutch, cant be as bad as the mazdaspeed 6 i did, that trans and Tcase were insane Heavy i did all the work myself on jack stands. only thing i had to replace other then the clutch/flywheel was the A-Arm Grease boots they were worn and just didnt make it after using a pickle fork on em lol
Lol that output shaft scared me but you are not suppose to hit it...
Basically the exhaust hanger bolts had the same thread pitch as the output shaft we threaded it then used a wire coat hanger and wrapped it around the bolt then the other end to a 3lb sledge hammer.
3 quick pulls and it was out
I am getting ready to pull my tranny to replace the clutch and flywheel, wish me luck!
How much of a PITA is it to reinstall the cradle/subframe if you decide to take it out?
I heard taking that out makes life much more enjoyable!!!
save yourself from total aggravation and remove it at all costs!
This is a great thread. I paid out the @$$ years ago when the stock went out, I would definitely give it a go myself now. But I also refuse to put anything but the best on my car now..
I can't believe that these clutches can be done in less than 6 hours 0.0
I read somewhere on here about some shop in NY doing evo clutch jobs in 3 hours for like $600! WTF
This is one of those things that I would gladly pay to have a professional do just for peace of mind. I'm sure I could do it, but I wouldn't want to sit there after I bolt everything back up 10 hours later and wonder if I really did torque everything perfect, line the clutch up right, orient the disc the right way, etc. A lot of places to make catastrophic mistakes.
