Turbo Timer Harness
Old Jul 28, 2012 | 11:39 PM
ASTEPW89's Avatar
Turbo Timer Harness
I just installed my apexi TT with a greddy plug and play harness. I fallowed the write up directly and I turned my car on and nothing from the turbo timer. So my question is will the greddy plug and play harness work with the apexi or do I need to get the one for the HKS,blitz, and apexi? If the greddy one is supposed to work with the apexi TT where should I look first for a problem. I bought it off of another member on here and he said it worked perfect when he pulled it out of his car.
Old Jul 28, 2012 | 11:55 PM
johnnydemz4G63's Avatar
did you tap into your E-brake?
Old Jul 29, 2012 | 12:27 AM
ASTEPW89's Avatar
No but I didn't think you had to. I thought you only had to do that if you wanted that option. That's how it worked at least on my greddy one that I had in my eclipse. Correct me if I'm wrong tho.
Old Jul 29, 2012 | 12:34 AM
I have an hks and did not tap into the e-brake and the timer was not functioning, tapped into my e-brake and problem solved.
Old Jul 29, 2012 | 12:53 AM
ASTEPW89's Avatar
I guess it won't hurt to try that seems like I've tried everything else.
Old Aug 5, 2012 | 08:39 PM
allwheelgrip007's Avatar
you can try grounding the e-brake wire to something, that should work.
