Valve Cover repaint/color
Old Mar 28, 2013 | 03:21 PM
supaduckie8113's Avatar
Whats up guys the paint on my valve cover is fairly discolored and i was planning on doing a repaint. I have two specific questions, is there a how/guide on how to do the repaint and does anyone know what the oem color is?
Old Mar 29, 2013 | 08:31 PM
Steeldon's Avatar
Do you plan on rattle canning it? I can't find the color code but this is the perfect time to paint it custom. This is all I can find with a quick google search: http://www.socalevo.net/forum/index.php?topic=112129.0
Old Mar 30, 2013 | 03:13 AM
i came across the same thread and i was gonna follow the same process, but i guess my main concern was the color. I cant figure out the color i wanna use the oem color but nobody knows what it is
Old Apr 2, 2013 | 11:08 AM
EvoSeanzie's Avatar
all i did was hose her down with aircraft remover, then scrubbed with a wire brush. then sprayed with engine primer, duplicolor engine paint, then vht clear
Old Apr 2, 2013 | 11:24 AM
wjamyers's Avatar
I scratched mine like a dumbass and wanted to touch it up with OEM but had same problem, it's a big mystery.
Old Apr 3, 2013 | 08:05 AM
mjev8's Avatar
If you want to do OEM just get some scrap metal and do colors that look close and hold next to the cover and see what it looks like. But I agree with Steeldon, now's your chance to do it custom. Whatever color you want.
Old May 14, 2013 | 12:47 PM
USAFJAM's Avatar
Why not powdercoat?
Old May 17, 2013 | 05:26 AM
Teal2nnr's Avatar
I would powder coat as its much more durable then paint. However if you went this route you would need to drill the baffles out, as well as drill and tap all the rivet holes so that you can put cap screws back in. This is necessary to make sure you get all the sand and dirt out from the sand blasting.
Old May 28, 2013 | 07:47 AM
vietnite42's Avatar
do powder coat if you can since it sounds like you beat the hell out of yours =P if you paint it then it might not last
Old May 28, 2013 | 08:11 AM
USAFJAM's Avatar
Why not just pay someone to powdercoat most you'll pay is $80 and it will take away a big headache.
Old Jun 10, 2013 | 08:09 PM
WI-EVOS's Avatar
just get it hydro-dipped!! look unique and last for a long time!!
Old Jun 14, 2013 | 09:55 AM
JaYr_EvO9's Avatar
best anwser^^^^^^^^
Old Jun 14, 2013 | 04:37 PM
Slickonice's Avatar
I don't know if anyone else had this issue. But when I painted mine it eventually cracked from the heat. The valve cover is magnesium and paint doesnt stick to it all that well I am told. So im having mine powder coated. But before powder coating the baffles need to be removed. There is a guide on here how to do it. Between ace hardware, home depot and harbor freight I was able to get everything I needed to remove the baffles and re install them with bolts.
Old Jun 18, 2013 | 12:28 PM
whotippedmycow's Avatar
Would white look really bad?
Old Jun 19, 2013 | 06:17 AM
vietnite42's Avatar
yes. you notice every single little blemish on it when it is white. it looks great when it's clean the first couple days but after that you will constantly get it dirty if you work on your car
