Evo 8 rexpeed side spat install
Whats up guys i needed some help with the rexpeed side spat install. I know its pretty straight forward with the screws and the 3m tape but im not sure exactly where on the side spat i should put the 3m tape. Is there a specific spot that i should put the tape and exactly how much do tape do i use? Any help would be appreciated
It's pretty simple. The tape can pretty much go anywhere on it. I put it around the edges, in between the bolts, anywhere you think it'd work. If you mess up, pull it off and redo it. You can try multiple times, although the tape is pretty strong... I hope you've at least TRIED on your own. This is probably the easiest install of any aftermarket item
stikllr13
May 11, 2017 03:46 PM
mrfred
12
Apr 1, 2012 06:41 AM
Darkrider3
May 4, 2011 09:24 AM
