evo 9 bumper sag under headlight
Old May 6, 2013 | 03:00 PM
Ev0ikon's Avatar
I am talking about part # 24 and 25.
Without #22 I don't think the bumper would sit proper either.
Old May 6, 2013 | 03:06 PM
vicariousthrill's Avatar
I actually have 24 25 and maybe I bent one a bit but forsure I need to get 22. and maybe its sagging more because of the license plate on that side and not having the middle reinforcement to hold it up more.
Old May 8, 2013 | 08:00 AM
NJ_evoIXgsr's Avatar
Veteran: Navy
I am running without the crashbeam. I have "sag". Three things I am looking at.
[a] Maybe get a fabricated L shaped for the bumper to sit on which could add rubber stoppers or something in that regards to increase or decrease spacing between bumper and headlights.
[b] Mitsubishiparts.net - states the fender screw set gets worn and needs to be replaced. Goto their website and look at "fender kit". Located by doing a search on here.
[c] I did notice that #8 on the diagram is missing from my bumper. I think that may play a big role as the two holding points are #s - 2, 4, 5, 6, and 7. In between those points is a huge gap in providing support.
In my setup, [c] may be due to no crashbeam so that is the reason for coming up with solution [a].
Old May 8, 2013 | 09:24 PM
TeachersEvo's Avatar
I do not have 22, 24 or 25 and also have sag. Do 22, 24 and 25 attach to the crash beam?
Good thread.
Old May 9, 2013 | 12:17 AM
Good thread.
i believe 24 and 25 provide support so bumper wont flex in high speeds and i believe 22 clips somehow to the crash beam. i found this picture below
Old Jul 8, 2015 | 02:41 PM
kyoo's Avatar
Originally Posted by evo8426
Those do not really do anything and do absolutely nothing for adjustment. The only way to get rid of the issue is to adjust the brackets that hold the crash beam itself. There are 2 brackets with 2 bolts each underneath the crash beam. Loosen them up a little bit, enough to wiggle them upwards, and then retighten. With the crash beam adjusted higher up on the car it pulls the bumper up with it.
is there any way to adjust the crash beam with the bumper still on?
Old Jul 8, 2015 | 02:58 PM
heel2toe's Avatar
Negative ghostrider. Sack up and pop off the bumper Oh and have fun with those clips for your undertray...
Old Jul 8, 2015 | 04:28 PM
kyoo's Avatar
boo I already vowed never to take off the undertray or bumper again lol. that and one of the screws holding the bumper on stripped so I can't really
Old Jul 8, 2015 | 04:32 PM
kaj's Avatar
kaj
sometimes i miss the spot where the bumper should rest and end up with that gap. it could be as simple as pulling it off, then lifting it a bit higher as you reinstall.
if not, compare brackets once the bumper is off.
this is the sole reason i run no undertray LOL
Old Jul 8, 2015 | 04:37 PM
FossilAus's Avatar
Not much use to you now but might help someone else who doesn't have crash beam
JDM cars don't use crash beam at all, the bumper hooks onto x2 metal brackets which are bolted to the chass (i'll find the part number for you) and the bumper 'hooks' onto these. Simples
Old Jul 24, 2015 | 12:16 PM
day day's Avatar
I have the same issue on the same exact side.
Old Aug 11, 2015 | 09:18 AM
rongdoer's Avatar
make sure 11 and 12 are pushed to most centered they can get inside the bumper. They hold the bumper out so it's taught across the front.
Old Aug 12, 2015 | 06:51 AM
Roginald's Avatar
My solution is not looking at the bumper too closely
Old Aug 18, 2015 | 07:56 PM
mrr5049's Avatar
Mine is doing the exact same thing ! All that plastic is broken off though that holds it, may try another method but it hasnt bother me too much. Good luck!
Old Aug 19, 2015 | 11:53 AM
Evonv91's Avatar
Just put a new oem bumper on mine and have same problem!
