Pin out for upper clutch switch (FFS) - JDM Evo 8
I have an EVO 8 JDM 3 plug ecu and for the life of me can’t figure out which pin I should wire the upper clutch switch into.
There seems to be two clutch switches, one which is activated when you fully depress the clutch pedal to start the car and another at the top of the clutch assembly that does not have anything connected to it.
I would like to activate NLTS but can’t find;
1. The correct Connector & part number
2. If the connector is wired directly to the ecu (pin out also needed) or if there are instructions on how to get it done below the dashboard.
Thanks....
Thanks....
Last edited by 400s; Jan 14, 2018 at 09:26 PM. Reason: Grammar and additional text
nudge120
Apr 2, 2010 03:41 PM
