Fuel pump wiring acces
Old Jul 25, 2021 | 11:27 PM
Luca Bernardi's Avatar
Hello, i have a problem, due to a bad shortcut on the fuel pump i need to replace all the pump wiring...the question Is, i need to remove the fuel tank to gain acces? Is there another easy way?
Old Jul 26, 2021 | 06:24 AM
Project_Broke's Avatar
No, you should be able to get to all the wiring through the access cover under the rear seat.
Old Jul 26, 2021 | 07:16 AM
Because i've tried ti pull, disconnecting the other side behind the passenger seat, tried to pull both ways but seems stuck, in the work shop manual seems wrapped toghether ABS wiring...maybe later i try with a little more force
McCool213
Sep 16, 2016 09:56 PM
k270kmh
Aug 11, 2007 03:23 AM
