AEM wideband with AEM Infinity
Old Aug 17, 2021 | 05:05 PM
Innovation-USA's Avatar
What's going on guy's, so I am running the AEM infinity on my 8 and I want to run the wideband o2 sensor to the Ecu but I would also like to have the gauge still installed so I can see what's going on with the AFR's. What is the best way to set up the gauge so I can see what the ECU is seeing?
Old Aug 18, 2021 | 03:59 PM
Lumpy Sticks's Avatar
5 Year Member
If your gauge outputs AEM Net, just tie those two wires back into the AEM Net on the Infinity. Done.
Old Aug 18, 2021 | 06:00 PM
That is super simple thank you for the response.
Old Aug 18, 2021 | 06:30 PM
I ordered the wideband extension harness from map so I can plug the O2 sensor directly to the Infinity and then I run the Green/White wire from the gauge to the aemnet plug? Should I just keep the power and ground wire where they are for the gauge or run all 4 to the AEMnet? As long as the gauge is getting power it should not matter right?
Old Aug 18, 2021 | 07:32 PM
5 Year Member
Don't even run the extention. There is no benefit. Just set it up in the wizard under input functions - lambda input - x series 1 and call it a day. I had a debate with an AEM tech and he said if you already have the gauge, its a waste of money to buy the adapter to run it directly to the ecu since they both react just as fast.
Old Aug 18, 2021 | 07:41 PM
oh ok yeah that makes sense I guess I will be returning the other harness and just hook it up how you said.
Old Aug 18, 2021 | 07:44 PM
5 Year Member
I mean you can do it how you said but at that point pull the gauge and harness out, sell them without the o2 sensor and go buy an aem net gauge. That way you can monitor whatever the ecu sees from that one gauge.
Old Aug 18, 2021 | 08:20 PM
done deal lol
mindoftw
36
Jul 17, 2013 07:58 PM
EriCS
Jan 10, 2010 11:53 AM
travail
AEM EMS
Sep 20, 2009 01:21 AM
SupaDoopa
14
Sep 9, 2008 09:37 PM
feldguy
Jan 16, 2005 12:56 PM
