Water Pump Bolts
Does anyone have a diagram showing where the water pump bolts go back in? When they were removed they got mixed up. When putting the pump back on I thought I had the bolts in the correct location but the top bolt is binding when it gets almost all the way in. I matched the longest bolt with the thickest part of the water pump because I assumed that was the correct placement.
Thanks |
PM me your email and I'll email the PDF of the service manual, it shows it in there.
You probably have it right. You are probably missing the alternator bracket.
-Em |
^ That was it. Thanks guys.
The following link will take you to the FSM page that describes the lengths. The grade 7 bolts are on the top left and on the bracket near the water pipe. The general layout is longest bolts go in the longest holes.
http://thefrost.net/randomfiles/tuni...pump_bolts.pdf Thanks to FlatStateVIII... my FSM didn't show these. |
