Supertech Dual Valve Spring and Retainer Install
Hey guys looking for some help. familiar with changing out regular springs and retainers but this is the first time ive done dual valve spring and retainers. Im installing the supertech dual valve spring and retainers, purchased from stm so i have the seats and seals and everything needed to install along with FP4R cams in my IX RS. If anyone could give me a brief step by step or some pictures of how it looks installed that be great. Thanks ahead of time!!!{thumbup}
If you have done regular set of springs these are no different then that. But if not youll have to but a valve spring remover http://www.amazon.com/Valve-Spring-R...sim_sbs_auto_3
or http://www.euroexportinc.com/store/t...ompressor.html |
Originally Posted by NewEvolutionIX
(Post 9726374)
If you have done regular set of springs these are no different then that. But if not youll have to but a valve spring remover http://www.amazon.com/Valve-Spring-Remover-Installer-Compressor/dp/B004NV1XTY/ref=pd_sim_sbs_auto_3
Just did the same exact kit on my car. Piece of cake if you've done regular springs before. No different... Just that you have a smaller spring inside a bigger one, and some serious tension!
Please be very CAUTIOUS and wear some eye protection for this install. |
sorry to bump an older thread but ive used a tool that helped me tremendously while installing my GSC beehive (Think Kiggly) and my friends supertech duals just fig i would share. I have the tool above except bluepoint and its a great tool it just sucks using it if your trying to do it your self. so here the link for the NEW tool i use on valvesprings
http://www.euroexportinc.com/store/t...ompressor.html youtube it and see videos! |
Thanks for the bump i actually just bought it :)
Originally Posted by prockish_03evo
(Post 9843767)
Originally Posted by TheBoz
(Post 9903246)
I also picked up this tool and installed my GSC Springs an Ti Retainers. With this tool it was easy as hell. I did my install with the head on the block.
I just put the piston to TDC and let the piston keep the valve closed.
I did the exhaust side first then did the intake side. |
That tool is pretty cool. But looks time consuming. I use Snap-on's valve spring tool that bolt across cylinder head and charge cylinder with air. I can do complete cylinder at once. Whole job takes about hour to hour and half.
http://buy1.snapon.com/catalog/item....re&dir=catalog
(Post 9843767)
