I need help on my coilover!
I have WORKS/Ohlins Stage IV Coilover Suspension. I would like to adjust the height myself but I need a little help! Yes, I'm a noob and it already came with the Evo I bought couple months ago. I have no idea where to start. I've had Function and Form coilover for my EG9 and yes I did work on it with a help of a friend. I just wanna know the step by step since Ohlins Stage IV Coilover Suspension looks a bit different.
Here's how it looks like! http://store.worksmotorsports.com/WO..._p/225.805.htm |
pics dont work
on my ohlins, the fronts on the bottom mount there is an allen bolt. loosen that bolt and remove. take the wrench and put it on the lower collar and spin it so that the WHOLE threaded section moves. then when u get it to the right height, insert allen screw and tighten. for the rears, just break loose the lower collar below the spring and spin the top collar (below the spring) to adjust the rear height. in the ohlins manual there is MARKINGS for the limit of the height. dont go HIGHER than the marking line on the threaded sleeve. that means there is 4-5 threads left holding it and its not safe to go further. just found the pic. wow you bought the double adjustable one. baller. |
Originally Posted by sujinX
(Post 10048631)
pics dont work
*bump
