Modifying a Evo 6.5 Tommi Makinen ?
:helpme::helpme:Hello guys , I just bought this stored 2000 Evo 6.5 Tommi Makinen Edition with 35,000 miles on it with a few mods on it and started driving it once a week then started racing it until it broke a piston .
I thought i was just going to overhaul the engine then i started ordering some parts then saying thats enough then ordering more and more . I just decided i wanted over 600awhp . I just want to know am i going in the right path . Ill list the mods it had when i bought the car which made 379awhp & 330tq . il also list the parts i bought after opening the engine to aim for the 600awhp . What do i need to install more or less ? https://cimg9.ibsrv.net/gimg/www.evo...a95c488823.jpg Mods When Made 379awhp & 330tq : -Hks exhaust system -Hks blow off valve -Hks dump tube -Hks turbo timer -AEM wideband -3 inch intercooler -2.5 inch intercooler piping -ID1000 injectors -AMS fuel rail -Aeromotive fuel pressure regulator -Aeromotive fuel pump -8an + 6an summit racing braided stainless steel fuel line -MAP exhaust manifold -Precision 38mm waste gate -GT 35 turbo -Blox racing boost controller -Haltech sport 1000 ECU New Parts Ordered : -Precision turbo 6466 , dual ball bearing , vband , T3 - .82 -Manley H-Beam rods -Manley Pistons , 86mm bore size , compression ratio 9.0.1 , stroke 88mm , rod length 150mm (std) -ARP head studs -ARP main studs -ARP cam gear bolt -ARP under drive pulley bolt -ACL main bearings -ACL rod Bearings -ACL thrust washers -Hks cam gear x2 -Hks fine tuning belt -Hks fine tunning timing belt -Hks spark plugs -Hks oil filter -Ati underdrive damper pulley -Kiggley HLA oil pressure regulator -Gsc balance shaft eliminator -Gsc zero tick lifters -Brian Crower camshafts 276/276 -Brian Crower springs -ACT Extreme 6 puck sprung clutch -Omni 4bar map sensor -OEM tensioner pulley -OEM idler pulley -OEM balance shaft pulley -OEM full engine gaskets & seals https://cimg0.ibsrv.net/gimg/www.evo...7fd01527e2.jpg |
