Modifying a Evo 6.5 Tommi Makinen ?
Old Sep 29, 2017 | 06:17 AM
vette557's Avatar
Question Modifying a Evo 6.5 Tommi Makinen ?
Hello guys , I just bought this stored 2000 Evo 6.5 Tommi Makinen Edition with 35,000 miles on it with a few mods on it and started driving it once a week then started racing it until it broke a piston .
I thought i was just going to overhaul the engine then i started ordering some parts then saying thats enough then ordering more and more . I just decided i wanted over 600awhp .
I just want to know am i going in the right path . Ill list the mods it had when i bought the car which made 379awhp & 330tq . il also list the parts i bought after opening the engine to aim for the 600awhp .
What do i need to install more or less ?
Mods When Made 379awhp & 330tq :
-Hks exhaust system
-Hks blow off valve
-Hks dump tube
-Hks turbo timer
-AEM wideband
-3 inch intercooler
-2.5 inch intercooler piping
-ID1000 injectors
-AMS fuel rail
-Aeromotive fuel pressure regulator
-Aeromotive fuel pump
-8an + 6an summit racing braided stainless steel fuel line
-MAP exhaust manifold
-Precision 38mm waste gate
-GT 35 turbo
-Blox racing boost controller
-Haltech sport 1000 ECU
New Parts Ordered :
-Precision turbo 6466 , dual ball bearing , vband , T3 - .82
-Manley H-Beam rods
-Manley Pistons , 86mm bore size , compression ratio 9.0.1 , stroke 88mm , rod length 150mm (std)
-ARP head studs
-ARP main studs
-ARP cam gear bolt
-ARP under drive pulley bolt
-ACL main bearings
-ACL rod Bearings
-ACL thrust washers
-Hks cam gear x2
-Hks fine tuning belt
-Hks fine tunning timing belt
-Hks spark plugs
-Hks oil filter
-Ati underdrive damper pulley
-Kiggley HLA oil pressure regulator
-Gsc balance shaft eliminator
-Gsc zero tick lifters
-Brian Crower camshafts 276/276
-Brian Crower springs
-ACT Extreme 6 puck sprung clutch
-Omni 4bar map sensor
-OEM tensioner pulley
-OEM idler pulley
-OEM balance shaft pulley
-OEM full engine gaskets & seals
vette557
11
Oct 5, 2017 03:07 AM
vette557
Sep 29, 2017 06:20 AM
i love my evo
Mar 13, 2009 11:19 PM
