Mechanical o2 Fix
This is how to make a mechanical o2 fix if you have a test pipe/resonator/high flow cat, that gives a cel. You can find it on ebay for about 15 dollars shipped. But why buy it when you can make it for 3 dollars using parts from your local Pep Boys?
First of all you will need 2 spark plug anti-foulers (18mm). It is made by the HELP! brand part#42002 or 42009. http://www.socalevo.net/gallery/albu...0/DSC01106.jpg You will also need a 1/2" drill bit and drill. Or a drill bit close to that size http://www.socalevo.net/gallery/albu...0/DSC01108.jpg Drill one one the anti-foulers so that the o2 sensor can fit. I recommend using a vise grip and lube for the drill bit if you ever plan on using it again. http://www.socalevo.net/gallery/albu...0/DSC01110.jpg This is how the hole should look after. If it doesn't come out nice use a dremel or a file. http://www.socalevo.net/gallery/albu...0/DSC01111.jpg Put the one anti-fouler you drilled and connect it on top of the one you didn't. Now you don't have to buy a electrical fix and splice your wires. Here it is installed. I recommend using anti seize on all treads. http://www.socalevo.net/gallery/albu...0/DSC01114.jpg http://www.socalevo.net/gallery/albu...0/DSC01115.jpg Here is one I tried and gave up on. http://www.socalevo.net/gallery/albu...0/DSC01112.jpg http://www.socalevo.net/gallery/albu...0/DSC01113.jpg |
ALL Discussions Go Here!
