Buddy Club "Secu-Timer" Turbo Time+Security System **IN STOCK**
BUDDY CLUB
**PM for best price**
***IN STOCK***
The very first turbo with security feature.
It has all the normal functions of the turbo timer and a very special new function -
security lock.when the security lock is enabled, the correct password must be
enterd before the engine can be started. The timer will not only protect the engine,
but also reduce the risk of the car being stolen.
Time display
Displays time and will flash when security funtion is enabled.
Voltage display
Displays battery voltage, with min/max voltage warning indication.
Turbo timer function
Adjustable between 10 seconeds to 99 minutes 99 seconds.
***IN STOCK***
Time display
Voltage display
^It will be a number code. You can input a 4 digit password. Its very easy to set the password in. The kit comes with instructions.
You can use a plug n play harness like other turbo timers. however, there will be 3 wires that you will still need to hardwired. Pmed you price.
