ARK Design Multi Fuction Display / Boost Controller / Rev-Shift Timer in stock!!!
ARK Desgin Multi Function Display
Get your hands on this hot new MFD! Features include:
- TFT display provides quick response with high resolution
- 2 analogue and 4 digital modes, multi fuctional up to 10 gauge display options and 8 at the one time
- Displays Boost, Speed, Throttle and Injector Duty
- Optional Sensors allow temp and pressure readings for oil and water
- Cool slim design body with large display
- Simple, unique design with high quality metal plate control
- Actual Size 80(L)mm x 50(H)mm x 10(W)mm
ARK Design Rev-Shift Timer
Comes in a compact body design (105 x 20 x 18 Milimeters) with easy settings. Has Left, Right button as well as up, down and push roller button. Features
* Pro Drive Idling - 1
o Auto Mode - Calculates the engine status before post drive idling, reducing the fuel consumption by engine
o Manual Mode - The post drive idle time can be manually configured by the driver
* Rev Shift Timing Display - 2
o RPM is detected and shown either with an alternator pulse or from ECU Rev Signal. The lamp also flashes to remind the driver to shift up
* Simple A/F
o The simple AF reading is displayed through O2 Sensor Signal from the ECU. It informs the driver about the current fuel consumption
o Battery Status and Charging status is displayed
* Hand Brake Safety
o Prevents Engine from running post drive idle mode according to hand brake status
ARK Design Boost Controller
Advanced Boost Controller (ABC) has a simple square body (W105 X D20 X H18 Milimeter) with easy to operate right left sew-saw switch and up down push to set roller switches, the operation has become hassle less! (Japanese utility application 506221619). The display can be seen clearly, the large high illuminated 7 segments LED changes display color according to the boost settings, at warning boost, white light flashes to ensure a comfortable drive.
* Compact design : The pressure sensor is packed inside the power box to minimize the components. The compact designed control unit and solenoid valve give the option of any installation locations.
* Two modes of boost pressure setting Possibility of setting A mode and B mode boost pressure
* Full colour LED changes colour according to boost pressure : In addition to the large LED which changes according to the boost pressure, the colour changes when the pressure moves from negative to positive. The LED has many user definable settings including colour and scaling in the positive pressure zone
* Warning display to boost pressure : Full colour LED will flash in white at the default pressure for warning. This feature can be used to visualize boost control pressure and dangerous zone. Furthermore, the warning colour can be changed to the user's preference
* Safety function : When the boost is raising abnormally, it automatically off the control and switch to normal control.
* Peak hold display : The peak of boost pressure is memorized.
PM for price, available now!
* Simple A/F
* Hand Brake Safety
Kami Speed
EvoX 'For Sale' Electronics / Lighting / Audio
Feb 20, 2010 03:55 PM
downforceinc
53
Aug 13, 2009 07:52 PM
downforceinc
Evo 'For Sale' Suspension / Brakes / Handling
18
Jan 5, 2009 11:34 AM
downforceinc
EvoX 'For Sale' External Engine / Power
Nov 17, 2008 12:11 AM
