Hks turbo timer type 1
Old Jan 22, 2009 | 04:49 PM
rick@sp's Avatar
Smile Hks turbo timer type 1
The All New HKS Turbo Timer PM FOR SPECIAL PRICING ONLY 5 WITH SPECIAL PRICING
In 1982 HKS introduced the world’s first Turbo Timer to assist in cooling down the turbocharger to prevent oil coking in the center bearing cartridge assembly. Oil "coking" occurs when a turbocharger is not properly cooled down and the oil that normally lubricates the center cartridge heats up and forms solidified oil deposits. A turbo timer allows an engine to idle for a preset amount of time after the ignition key has been turned to the off position and removed. By allowing a turbocharged engine to idle, oil continues to pass through the turbo until it has cooled down to the point where oil "coking" will not occur. Re-designed for 2008, the all new Turbo Timer Type-0 and Type-1 feature a new, slim low profile design with a separate LCD display and control unit following the same design concepts as the current HKS EVC and A/F Knock Amp. The Turbo Timer Type-0 features a red LCD backlit display for easy visibility, 2 timer modes, and a battery voltage meter with a peak value indication and warning function.
The Turbo Timer Type-1 features a light blue LCD backlit display and has the same basic timing and voltage features as the Type-0 plus several monitoring and measurement functions. The Turbo Timer Type-1 features an Auto mode for the timer function allowing the Turbo Timer to automatically calculate optimum idling time according to the most recent driving pattern. Vehicle speed and RPM can be displayed on the Type-1's LCD monitor and a speed warning level can be set. A two-stage RPM warning can also be set and used as a shift indicator. When a warning level is reached the Type-1's LCD monitor will blink and an audible beep will sound. The HKS Turbo Timer Type-1 also features various measurement functions including 1/4 mile timer, 0-60 timer and a stopwatch function that can be used for lap timing. The Turbo-Timer Type-1 can read in either MPH/SAE or KPH/Metric.
Old Jan 27, 2009 | 06:05 PM
rick@sp's Avatar
bump!!
Old Jan 30, 2009 | 09:46 PM
J Yim's Avatar
Does this come with an evo harness for easy install? Or is this install more difficult?
Old Jan 31, 2009 | 01:03 PM
Aar0nsite's Avatar
PM deployed!
aaron
Old Feb 7, 2009 | 10:54 PM
Evo9MR310's Avatar
i would like to buy
I would like to buy is the installation simple and harness kits are included for a evo 9? and do you have a red led version to match my guages? and pricing?
TopSpeedAutoSport
EvoX 'For Sale' Electronics / Lighting / Audio
102
May 6, 2011 03:46 PM
Z1 Performance
Evo 'For Sale' Exterior Styling
Nov 5, 2004 07:21 PM
Boost Solutions
Jun 12, 2004 03:29 PM
