NEW! Perrin EBCS Pro 3 port Boost Solenoids!
Old Jun 4, 2010 | 03:05 PM
Speed Element's Avatar
Exclamation NEW! Perrin EBCS Pro 3 port Boost Solenoids!
The EBCS Pro Series 3-Port Electronic Boost Control Solenoid is designed to control todays high performance wastgates with it's ultra fast response and bomb proof design.
Aluminum & Stainless Steel Construction
No plastic here! Main valve body of the EBCS pro is made of corrosion resistant stainless steel with powder coated aluminum coil cover.
Direct Plug and Play Harness
Perrin's OEM type male connector is specific to all Subaru and Mitsubishi applications.
Compatible with OEM ECU & Stand Alone ECUs
Custom made solenoid coil and valve specific to PERRIN specs, to work with OEM ECU. Will not throw check engine lights.
Includes:
-Boost Control Solenoid
-Wiring Harness With OEM Plug
-Mounting Hardware
-Mounting Bracket
-6ft Vacuum Hose
-Vacuum connector
-Instructions
-Warranty
Only $109.99 Shipped! ORDER HERE
