TOMEI Engine Internal ** Cam shaft, Cam Gears, Spring, Solid Lifter , etc ***
TOMEI EVO 9 MIVEC CAMS - $PM FOR PRICING
http://www.tomei-p.co.jp/top/e-top.html
Here are some parts that we have in stock and ready to ship !
TOMEI PON Camshaft with Cam Gears Package - $950 Shipped Per Set (2 x cams, 2 x gears)
Good For Moderate Modified Application
TOMEI PRO Cam Shaft (Solid or Lash) With Cam Gears Package - $950 Shipped Per Set (2 x cams, 2 x gears)
Good For Heavy Modified Application
Need Additional Accessoreis like Solid Pivot or Tomei Spring - Good For 500+ WHP
Available in Lash Or Solid Stype, 260 (10.7 mm Lift), 270 (11.5 mm lift) or 280 (11.5mm lift)
TOMEI EVO 9 MIVEC CAMS AVAILABLE TO SHIP - IN STOCK NOW !
TOMEI 4G63 Spring - $299 shipped
Approximately 12mm lift. Needed for high lift cams !
TOMEI 4G63 EVO 1~3 and EVO 4+ Cam Gears - $319 Shipped Per Set of 2
Super lightweight duralumin Lightweight duralumin was overly adopted as the material of both pulley part of an outer, and an inner plate portion to realize super-lightweight body. Super-high durability By coating with hard almite on the surface, durability of the pulley have raised dramatically. It can easily be used for the drag racing cars that exceed 1000horse power and 10000RPM.
Designed only for each IN and EX pulleys With individual design of IN and EX, the adjustment part of both IN and EX pulley comes to its top when the engineユs TDC for easier valve timing adjustment
TOMEI Head Gasket - $280 shipped
Available in 1.0mm to 1.8 mm, 86.5 mm Bore
TOMEI Solid Pivot Kit - $720 shipped
In order to make cam clearance maintenance-free, and achieve operation sound reduction, hydraulic lash adjuster is adopted to SR20 engine. However, when aiming at high rotation and a high output by engine modification, it is important to improve the reliability of head parts and to make valve drive correctly as the cam profile. Accordingly, it is necessary to eliminate the function of lash adjuster. We adopt solid pivot system to enable cam clearance adjustment, while keeping total height of pivot of each cylinder fixed. Thereby, it is possible to build much precise head system in shorter time compare to the others. Moreover, improvement in reliability and the low price were realized at the same time by having reduced the number of parts.
TOMEI Oil Thermostat Killer - $49 shipped
TOMEI Head Studs Set or Main Studs Set - $499 shipped
************************** MORE PERFORMANCE ITEMS **************************
TOMEI Complere E/G 4G63 EVO7-8 MR GENESIS-1 Starting At $7500
TOMEI Complere E/G 4G63 EVO7-8 MR GENESIS-2 Starting At $11800
TOMEI 4G63 - 22 Stroker Kit Starting At $4900
85.5mm or 86.0 mm option, Piston, Full Counter Crankshaft, and Rods included
TOMEI 4G63 Full Counter Crankshaft - Starting At $4900
94mm Stroke, special piston required.
Full Counter Weight - By preparing counter weight on every cylinder, making inertia power balance so that bent of the crankshaft is suppressed and vibration and friction is reduced, while the reliability of bearing is raised. (Applied to all engine model excluding CA)
Route Lubrication Two- Route oil supply from two journals secures crankpin an enough amount of oil supply. Moreover, X shape oil passage enables supplying oil using the centrifugal force of a crankshaft; reliability of the oil supply at high RPM is improved. Furthermore, and resistance of oil flow is reduced by giving a modification on oil hole exit. (Applied to all engine model excluding CA)
Balance Rate - Counter weight has its original shape that is designed with theoretical analysis, to secure the proper rate of balance (rate which negates the inertia power of a reciprocating movement) while reducing its weight.
Edge Shape Designed - with Hydrodynamics At high RPM, counterweight rotates at more than 200km/h inside the crankcase through the oil and air. We designed the edge shape of the counterweight hydro-dynamically sharp so that less resistance will occur even at high rotation. (Applied other than CA)
Forged SCM435 Material - We selected chrome moly steel as a material (STD: regular steel) and forge it in the mold to improve the organization of crystal. As a result, metal flow is formed along with the shape of crankshaft that gives 2 times more strength to the metal than before.
WPC Finish - WPC finish to prevents pulley and pulley holder to be worn and keeps good maintenance of the engine. (Applied to RB engines)
TOMEI EVO IX PON CAMS (MIVEC)
260 intake 10.7mm lift
260 exhaust 10.2 mm lift
ETA: End Of May. Taking Pre-Order Now
PM For Pricing Camshaft with Cam Gears Package or Camshaft Only
TOMEI EVO 4G63 Oil Buffle
Best For Track Racing. Keep Oil Circulation consistant
hi:
we have 10 sets reserved from TOMEI !
Call us to pre order them !
let me know !
Mark.
www.ravspeconline.com
let me know !
Mark.
