AEM Water injection kit 395.10 shipped!!!! (Inside the 48)
Old Jul 20, 2009 | 09:29 AM
teamturbo's Avatar
AEM’s Water / Methanol Injection Kit reduces air inlet temperatures and exhaust-gas temperatures, which allows you to increase boost pressure and advance timing without having to run higher-octane fuel. It’s like getting to run 100+ octane gas for the price of Premium!
AEM’s Water / Methanol Injection Kit includes all the features necessary to do water/methanol injection right. No hidden costs or optional components are required. Unlike other popular kits on the market, we include a one- or five-gallon tank with a fluid level sensor standard. Also, because we think engine protection is a requirement, not an option, we include our Boost Safe output in every controller we design. This feature allows you to retard timing or reduce boost via a ground output if the system runs out of fluid or detects an error. With the AEM Water / Methanol Injection Kit, you get all the best features in one low priced kit.
* Universal kit includes everything you need for installation
* Boost Safe lets you retard the timing or reduce boost if the system runs
* Progressive, controller-driven 150-PSI pump provides boost-dependent
variable flow
* One gallon tank with integral fluid level sensor
* Dash light for system status and low fluid warning
* Methanol Compatible (up to 50% in solution with water)
* Includes three jets to match your power requirement
