Carbonetic Clutch!!!!!!
Carbonetic Carbon Blade Clutch Mitsubishi EVO VIII, IX
Th world's first OEM replacement Carbon clutch disc which has all the advantages of more expensice Carbon clutches. But priced liked performance metal clutches.
At quick shift th specific gravity of the Carbon is 1/5 of iron. By attaching our carbon material on the outer edges of the clutch disc, an ultra low inertia is released which cannot be accomplished by conventional clutches. The low inertia makes quick shifting very easy and at the same time it minimizes the damages to the scynrco gears.
The new carbon clutch has sprung centre damper in order to achieve an easy operation and to reduce the impact to the transmission at the engagement. The Blade Carbon clutch has been tested and can hold 450+ BHP with a comparative torque figure; tests have shown the clutch to hold even more. (Depending on pressure plate).
Key Features:
* HP Capacity at Wheel: 400 HP
* Clamp Load Increase:18%
* Number of paddles: 4
* Type:Light tuned turbo
* Application: Street/Roadrace
* Chassis code: CT9A, CZ4A
* Engine code: 4G63T, 4B11
Retail $915.00, yours for $650.00!
We have only 1 in stock!
Thanks,
Phil
Key Features:
Thanks,
Phil
