ACL Race Bearings - Back in Stock at Extreme PSI!
Old Jun 5, 2012 | 04:11 PM
extremepsi's Avatar
Gold Sponsor
ACL Race Bearings are back in stock at Extreme PSI
Click here to order!
ACL Race Series Performance Engine Bearings
The unique combination of design, metallurgy and engineering come together to
deliver what drivers expect from high performance Tri-metal engine bearings.
Designed to withstand higher RPM conditions, ACL Race Series Engine Bearings are
available for many of the popular 4, 6 & 8 cylinder applications and feature:
- High strength overlay plate with reduced thickness
for improved fatigue properties
- Hardened steel backs on all rod bearings to
improve the support of the bearing lining and assist with bearing retention in
the housing.
- Increased crush for improved bearing retention
-Elimination of flash plating on the back of the
bearings to improve heat transfer through the bearing sand to maximize the grip
between the bearings and its housing.
-Increased eccentricity to compensate for bore
distortion at high rpm and to assist in the formation of hydrodynamic oil films.
- 3/4 grooved Main Bearings to optimize bearing load
carrying surface area and oil flow to the con-rod bearings.
- Tight consistent wall tolerances to help you
maintain consistent clearances.
-Enlarged ID chamfers on bearing edges where
required to accommodate large fillet radius on performance crankshafts.
Thanks,
Tony
www.ExtremePSI.com
1-800-PSI-4502
215-244-4295
sales@extremepsi.com
