Unbeatable Pricing: Carillo, Wiseco, Eagle, ACL, And More!
MAPerformance - Proud to be your number one source for all things Tomei!
Mr. Seiichi Suzuki initially forged TOMEI is a tuning factory for race cars back in 1968. (Established as TOMEI JIDOUSHA Co. Ltd). From that day onwards TOMEI achieved excellent results in various motor sports categories. TOMEI was then recognized for its technology, performance and reliability that we had cultivated into our own design products and had a large support base from motor sports end users and tuners. Then the "TOMEI" brand was born through experience.
With the new market trends & demands, motoring enthusiasts wanted better performance to suit the new modern lifestyle. This trend helped set the stage where originality can play an active part in the motor sports scene and personal motoring lifestyle.
From Exhausts, to engine internals, to turbos, Tomei offers products to fill just about every category:
Tomei's has created a new line of titanium exhausts for latest import cars. Tomei titanium exhausts are designed for the best power and response, but keeping the great characteristics of the original engine. Each exhaust is tuned for each car and the least restrictive angles are chose to optimize power and torque. The thin titanium exhaust gives a true race style exhaust, but can also toned down with the included silencer.
The PROCAM series are for the serious users who need results when every milla-seconds count.
TOMEI Valve Springs
In terms of transferring the exact movement of the camshaft, the highest quality valve spring is required to the high RPM, high powered tuned engines. We developed our products with the most careful choice of the material, coating and the other technologies. Then we repeated severe tests to our pre-production in order to give the best quality that is performed in any situations.
Features
Reliability in high RPM, and improvement in an initial response
High durability against metal fatigue
High durability against the shocks from jump and bounce
High durability against surging
High sag resistance
Tomei Adjustable Cam Gears are designed specifically for each and every application. The pulley and gear are made from Duraluminum material for less weight and increased strength. Tomei adjustable cam pullies are sliding types with timing degree markings that allow the fine tuning of the valvetrain for optimized power.
Anything and everything Tomei offers, WE offer! Please feel free to shoot me a PM with any inquiries!
Nate
TOMEI Valve Springs
Features
High sag resistance
Nate
MAPerformance updated inventory clearance!
We just recently updated out inventory clearance section on our website and there are some pretty awesome deals to be had for just about every car you can imagine.
Inventory Clearance Special!
EVO X
EVO 8/9
Again, I'm linking you directly to the EVO sections, but we have everything from DSM to Camaro to Subaru at amazing deals and discounts! Click below to check out the entire clearance!
EVO X
EVO 8/9
MAP is proud to offer Injector Dynamics brand new line of 1300CC rated injectors!!
The ID1300 is an all new injector, designed in partnership with Bosch Motorsport
This collaboration has given us the ability to design a high flow injector with characteristics specific to the needs the high-performance tuner.
The ID1300 was designed with alternative fuels in mind, and is the only performance injector available with all stainless internals. It is compatible with all known fuels, and will stand up to the corrosive nature of alcohol better than any injector on the market.
While the ID1300 was designed with an eye towards ethanol fueled engines, we have accounted for the occasional need to convert back to gasoline. The ID1300 has a minimum fuel mass compatible with gasoline use, and will provide exceptional idle and cruise behavior under these conditions.
In addition to its multi-fuel capabilities, the compact body of the ID1300 allows fitment in 200+ applications, making it the most versatile injector in our lineup.
Follow the shortcut links below for specific data, or scroll down to see all data for the ID1300.
Basic Specifications
Nominal Flow Rate - 1340cc/min @ 3.0 Bar (43.5 psi) Using Iso Octane at 52 Degrees C (125 Degrees F)
Maximum Differential Fuel Pressure - 6.0 Bar (87.0 psi)
Fuel Compatibility - Compatible With All Known Fuels - (Designed Specifically for Alternative Fuels)
Electrical Connector - USCAR
Precision Turbo - NOW Stocking all popular Turbo's!
In an attempt to cut down delivery times for all popular turbos, PTE is now stocking on the shelf, ALL popular options so that WE can get them shipped out to you ASAP!
PM me for pricing anything and everything Precision Turbo!
Featuring the latest and greatest in compressor and turbine wheel technology from Precision, the PT6266 CEA offers a unique combination of Competition Engineered Aerodynamics (CEA) with both hot and cold sides! Offering a 30-45 horsepower increase over similarly sized turbine wheel equipped turbos, the PT6266 CEA is the perfect choice for those wanting to make more power without changing their current system.
Precision customers have a history of setting records and getting noticed. They don't sit in the stands watching the action – they're the ones making it happen. Innovation is a collaborative process and we focus our efforts on you. Get involved and be a part of the action today with .
SOME of the features PTE Turbos include are:
• Exclusive CEA (Competition Engineered Aerodynamics) compressor wheel machined from a 2618-aluminum forging
• Higher efficiency and faster transient response for maximum power and performance
• Available with either a Hydrodynamic 360° thrust bearing system, or an Air-cooled, dual ceramic ball-bearing center housing rotating assembly (CHRA)
MAPerformance is proud to announce the release of our NEW H11 Headstuds for EVO X!
Need more clamping force than regular chromoly headstuds afford? Making big power on your EVOX and concerned about lifting the head? MAYBE you just want the accurate torquing our dog point feature provides...WHATEVER the reason...if you are building a big power EVO X...these headstuds should be on your list!
Consider these an insurance policy for your head gasket...
If you're looking to make big power but don't like the idea of lifting your cylinder head and replacing head gaskets frequently these are exactly what you need! These studs are manufactured specifically for us by A1 Technologies and utilize an H11 material that is much stronger than the typical 8740 chromoly and yields a tensile strength of 260,000 psi. They are also provisioned with a hex broach on the top of the stud enabling you to install them with the cylinder head on the car if necessary.
What is so different about these head studs?
The MAP Ultimate Duty Head Studs include an additional feature known as a "dog point" (shown below) that seats the stud in the block and preloads the fastener for an accurate and repeatable torque sequence.
Applications and Notes
Mitsubishi Evolution X 4B11T
Suits all USDM / JDM / European Models
Important Note: This material is easily contaminated and subject to stress corrosion. It must be kept well oiled and cannot be exposed to moisture.
Torque Specs
95 ft/lb with moly-lube
Prices start at: 239.99
MAPerformance not only carries every major wideband on the market, we also guarantee the best price! Whether you like the price of the PLX DM-5 / SM-AFR package or the functionality of the Zeitronix LCD bundle MAPerformance is your one stop shop for wideband oxygen sensor systems!
Please contact us for unbeatable pricing on these products, also keep in mind we will match or beat any competitors pricing on so called "package deals"!
: Send us a PM|||||
: NateAtMAP|||||
: 1-888-MAPERFORMANCE x 114|||||
: Nate@MAPerformance.com
[SIZE=\"4\"]MAPerformance - YOUR resource for the best pricing around on Competition Clutch AND ALL clutch solutions.[/SIZE]
Competition Clutch specializes in manufacturing sport compact assemblies from street driven to full race applications. You will find our products being proudly used in some of the fastest sport compact race cars in the country, including a number of the most recognized industry icon vehicles.
Competition Clutch, featuring their all new Stage 3 Segmented Ceramic Clutch Kit
This segmented Ceramic material with a performance pressure plate will provide the ultimate in street and strip combinations. This assembly is suited for 150% increase in torque capacity. Provides quick but smooth engagement and extended life.
[SIZE=\"4\"]MAPerformance Clutch Master Cylinder Upgrade (Mitsubishi Evo X)[/SIZE]
[SIZE=\"5\"]Starting at 149.99?[/SIZE]
If you\'ve experienced a clutch master cylinder failure or are simply being proactive, MAP is here to help. We have seen the stock plastic clutch master cylinder fail with upgraded clutches and/or spirited driving; Here is a solution that anyone should be able to install with basic hand tools from the comfort of your own garage.
With this kit there is no need to remove the pedal assembly and cut the ball joint as we include a billet ball joint attachment. Additionally, pedal height is easily adjustable by breaking loose the jam nut, removing the clip, and threading the balljoint to your desired pedal height. A braided stainless steel line replaces the original line as well.
This is a must have upgrade for Evo X owners if you are installing an upgraded clutch, don\'t get left stranded!
PLEASE NOTE: We offer this kit with or without a stock replacement clutch master cylinder. If you would like to include a clutch master cylinder you have your choice of aftermarket or OEM Mitsubishi. We have not had any reported issues with the aftermarket clutch master cylinder and offer it to you as a cost effective alternative to the OEM unit.
[SIZE=\"5\"]MAPerformance updated inventory clearance![/SIZE]
[SIZE=\"4\"]We just recently updated out inventory clearance section on our website and there are some pretty awesome deals to be had for just about every car you can imagine.[/SIZE]
[SIZE=\"4\"]Inventory Clearance Special![/SIZE]
[SIZE=\"5\"]EVO X[/SIZE]
[SIZE=\"5\"]EVO 8/9[/SIZE]
[SIZE=\"4\"]
Again, I\'m linking you directly to the EVO sections, but we have everything from DSM to Camaro to Subaru at amazing deals and discounts! Click below to check out the entire clearance![/SIZE]
[SIZE=\"4\"]
[SIZE=\\\"5\\\"]MAPerformance updated inventory clearance![/SIZE]
[SIZE=\\\"4\\\"]We just recently updated out inventory clearance section on our website and there are some pretty awesome deals to be had for just about every car you can imagine.[/SIZE]
[SIZE=\\\"4\\\"]Inventory Clearance Special![/SIZE]
[SIZE=\\\"5\\\"]EVO X[/SIZE]
[SIZE=\\\"5\\\"]EVO 8/9[/SIZE]
[SIZE=\\\"4\\\"]
Again, I\\\'m linking you directly to the EVO sections, but we have everything from DSM to Camaro to Subaru at amazing deals and discounts! Click below to check out the entire clearance![/SIZE]
[SIZE=\\\"4\\\"]
