Piston/Rod Combos.. Wiseco/Manley... Manley/Manley
Old Sep 4, 2013 | 12:43 PM
PRS's Avatar
PRS
So, for the month of September, we at PRS will be offering the following Piston/Rod Combos.
Wiseco Pistons & Manley H Beam Rods
Wiseco Piston Part Numbers
7 Bolt 93+ Eclipse (Evo1-3)
Part # Application Bore Size Compression Ratio
K548M85 4g63 7bolt 85.00mm (Standard Bore) 8.3:1
K548M855 4g63 7bolt 85.50mm (+.020" Overbore) 8.3:1
K548M86 4g63 7bolt 86.00mm (+.040" Overbore) 8.3:1
K548M865 4g63 7bolt 86.50mm (+.060" Overbore) 8.3:1
K548M87 4g63 7bolt 87.00mm (+.080" Overbore) 8.3:1
K597M85 4g63 7bolt 85.00mm (Standard Bore) 9.0:1
K597M855 4g63 7bolt 85.50mm (+.020" Overbore) 9.0:1
K597M86 4g63 7bolt 86.00mm (+.040" Overbore) 9.0:1
7 Bolt 4g63 w/ 2.4L 4g64 Crank (2.3 Stroker)
K596M85 4g63 7bolt 2.3 Stroker 85.00mm (Standard Bore) 9.0:1
K596M855 4g63 7bolt 2.3 Stroker 85.50mm (+.020" Overbore) 9.0:1
K596M86 4g63 7bolt 2.3 Stroker 86.00mm (+.040" Overbore) 9.0:1
Manley Rod Part Numbers
Part # Application
14022-4 STD Rod
Normally $879.98. Now only $815.00 + tax & shipping
ADD ACL Race Bearings For $149.99
ADD ARP Main Studs For $75
Old Sep 4, 2013 | 01:04 PM
PRS's Avatar
PRS
Wiseco Pistons & Manley I-Beam Rods
Part # Application
14403-4 STD Rod
Normally $1,279.98. Now only $1,175.99 + tax & shipping
Old Sep 4, 2013 | 01:52 PM
PRS's Avatar
PRS
Manley Pistons & Manley H Beam Rods
2.0L 4G63 Pistons
Use the following part numbers if you are using a 7-Bolt 4G63 Block with a Factory-Stroke 88mm Crank and Factory-Length 150mm Rods.
606000C-4 7 Bolt 4G63 85.0mm (Std Bore) 8.5:1
606005C-4 7 Bolt 4G63 85.5mm (+0.020" Over Bore) 8.5:1
606010C-4 7 Bolt 4G63 86.0mm (+0.040" Over Bore) 8.5:1
606015C-4 7 Bolt 4G63 86.5mm (+0.060" Over Bore) 8.5:1
606020C-4 7 Bolt 4G63 87.0mm (+0.080" Over Bore) 8.5:1
606100C-4 7 Bolt 4G63 85.0mm (Std Bore) 9.0:1
606105C-4 7 Bolt 4G63 85.5mm (+0.020" Over Bore) 9.0:1
606110C-4 7 Bolt 4G63 86.0mm (+0.040" Over Bore) 9.0:1
606115C-4 7 Bolt 4G63 86.5mm (+0.060" Over Bore) 9.0:1
606120C-4 7 Bolt 4G63 87.0mm (+0.080" Over Bore) 9.0:1
606200C-4 7 Bolt 4G63 85.0mm (Std Bore) 10.0:1 Flat Top
606205C-4 7 Bolt 4G63 85.5mm (+0.020" Over Bore) 10.0:1 Flat Top
606210C-4 7 Bolt 4G63 86.0mm (+0.040" Over Bore) 10.0:1 Flat Top
606215C-4 7 Bolt 4G63 86.5mm (+0.060" Over Bore) 10.0:1 Flat Top
606220C-4 7 Bolt 4G63 87.0mm (+0.080" Over Bore) 10.0:1 Flat Top
2.0L Long-Rod Pistons
Use the following part numbers if you are using a 7-Bolt 4G63 Block with a Factory-Stroke 88mm Crank and Manley 156mm Long Rods.
617000C-4 7 Bolt 4G63 w/ Manley 156mm Long Rod 85.0mm (Std Bore) 8.5:1
617005C-4 7 Bolt 4G63 w/ Manley 156mm Long Rod 85.5mm (+0.020" Over Bore) 8.5:1
617010C-4 7 Bolt 4G63 w/ Manley 156mm Long Rod 86.0mm (+0.040" Over Bore) 8.5:1
617015C-4 7 Bolt 4G63 w/ Manley 156mm Long Rod 86.5mm (+0.060" Over Bore) 8.5:1
617020C-4 7 Bolt 4G63 w/ Manley 156mm Long Rod 87.0mm (+0.080" Over Bore) 8.5:1
2.3L Stroker Pistons
Use the following part numbers if you are using a 7-Bolt 4G63 Block with a 100mm Stroker Crank and Factory-Length 150mm Rods
608000C-4 7 Bolt 4G63 w/ 100mm Stroker Crank 85.0mm (Std Bore) 8.5:1
608005C-4 7 Bolt 4G63 w/ 100mm Stroker Crank 85.5mm (+0.020" Over Bore) 8.5:1
608010C-4 7 Bolt 4G63 w/ 100mm Stroker Crank 86.0mm (+0.040" Over Bore) 8.5:1
608015C-4 7 Bolt 4G63 w/ 100mm Stroker Crank 86.5mm (+0.060" Over Bore) 8.5:1
608020C-4 7 Bolt 4G63 w/ 100mm Stroker Crank 87.0mm (+0.080" Over Bore) 8.5:1
2.4L 4G64 Pistons
Use the following part numbers if you are using a 7-Bolt 4G64 Block with a 100mm Stroker 4G63 Crank (or a stock 100mm 4g64 crank) and Factory-Length 150mm 4G63 Rods
613000C-4 7 Bolt 4G64 86.5mm (Std Bore) 8.5:1
613005C-4 7 Bolt 4G64 87.0mm (+0.020" Over Bore) 8.5:1
606015C-4 7 Bolt 4G64 86.5mm (Std Bore) 10.0:1
606020C-4 7 Bolt 4G64 87.0mm (+0.020" Over Bore) 10.0:1
Part # Application
14022-4 STD Rod
14020-4 Long Rod H Beam (+6mm)
Normally $849.98. Now only $806.43 + tax & shipping
Old Sep 4, 2013 | 02:34 PM
PRS's Avatar
PRS
Manley Pistons & Manley I-Beam Rods
2.0L 4G63 Pistons
2.4L 4G64 Pistons
Part # Application
14403-4 STD Rod
14421-4 Long Rod I-Beam (+6mm)
Normally $1,259.98. Now only $1,218.43 + tax & shipping
Old Sep 5, 2013 | 08:36 AM
PRS's Avatar
PRS
Who wants some goodies??
Old Jan 25, 2014 | 09:58 AM
Miasma987's Avatar
Not sure if you guys still have these pricing a up.
But I'm looking for 7 bolt 156mm Manley H-plus rods with arp 625 studs, and Manley pistons, 9.1:1 86.5mm stroker pistons to match the long rod combo.
This is for my 2.4l dohc
Pm me pricing for T3B2M8
12WWGSR91
26
Oct 31, 2015 11:04 AM
RealStreet
Evo 'For Sale' Engine Internals and Drivetrain
31
Jun 10, 2014 10:54 AM
RealStreet
63
Oct 17, 2012 09:12 AM
Piro Fyre
Dec 8, 2011 07:37 PM
bertune
16
Feb 4, 2010 07:11 PM
