ACT Full Face Street Clutch Assembly 545.00 SHIPPED
Well, here's the deal. I think im the only Evo/DSM guy here at Stripper, so I'm gonna jump in here and try to give the hook ups. I'm going to do this kit for 545 shipped to your door if you're in the US. If you want a flywheel or anything else at all, we can workout a better deal probably. I carry everything and can usually beat anyone's price.
Call and ask for Brian. I don't think anyone else here would give this price like I am. Don't tell! :lol: Toll free 866-708-7744 I'm here from 5-9 eastern time. Thanks for the space! -Brian http://i17.tinypic.com/2ryhv15.jpg ACT Clutch Kit with ACT Heavy Duty Pressure Plate and ACT Performance Organic Street Disc. ACT Heavy Duty Pressure Plates provide increased torque capacity, durability, and extended clutch life. What makes ACT Pressure Plates the highest standard in the industry? First, ACT manufacturing always begins with new units. ACT Pressure Plates are not rebuilt from worn out parts. Second, pressure is increased the right way. Altering the geometry alone is not enough. Instead, ACT engineers a stronger diaphragm. ACT diaphragms are heat-treated using an exclusive 3-stage process and the release bearing contact area is hardened to reduce wear. Third, ACT designs the pressure and release travel of the unit to be in the optimum working range. Finally, ACT assures consistency and precision by using proven assembly procedures. Every unit ACT produces is accurately balanced and tested. ACT Street Discs are designed for smooth engagement, quiet operation and improved durability using only the best organic, spring center designs. When an Act Modified Street Disc is available, the suffix "MM" appears in the disc part number. The marcel of the disc has been modified to enable quicker action. When a special ACT Performance Organic Street Disc is available, the suffix "SS" will appear. These discs use special steel backed performance linings designed to withstand high heat and abuse. Most of these "SS" discs are also modified for quicker shifting. What is all the hype about different lining materials available? ACT still contends that nothing can beat a good quality organic disc for street use. Virtually all the premium sport car manufacturers use organic discs. This kit includes these components: MB017 - Heavy Duty Pressure Plate MBSD088S - Performance Street Disc RB601 - Release Bearing AT03 - Alignment Tool Torque Capacity: 497 ft/lbs. |
bump it up
