Downpipes as far as the eye can see
Downpipes... i got TONS in Stock!!!!!!
B&B Downpipe
The downpipe utilizes the factory donut gasket for a perfect fit. The 3 inch diameter stainless steel piping gets your turbo air flow movin just right. The 1/2 inch thick flanges are laser cut and ensure no leaks. The downpipe fits with the factory underbrace and bolts on to aftermarket catpipes or the stock catalytic converter.
$313.99
Espelir Downpipe
Japanese tuning power Espelir has just released a brand new Downpipe for the Mitsubishi EVO VIII. This downpipe is full stainless steel with thick flanges and tig welded hangers which give the downpipe a perfect fit. The turbo to downpipe flange uses the factory donut gasket. The diameter of the downpipe is 3 inch for best flow. The downpipe gains about 12 whp and fits with the stock cat pipe or aftermarket cat delete pipes.
$169.99
Helix Downpipe
The Helix EVO 8 downpipe replaces your undersized factory downpipe in favor of a full 76mm (3") downpipe. The Helix downpipe is one of the largest on the market. Constructed of SS304 Stainless steel it features CNC machine mandrel bending which allows it to clear the factory lower arm bars (where many others don't). TIG welded, with the ever important CNC machined upper flange that is critical for proper seating of the stock donut gasket. This downpipe yields about a 8-10HP gain on a mildly modified car.
$304.99
Perrin Downpipe
The brand new Perrin downpipe for your Mitsubishi EVO VIII is now available. 3 inch stainless steel with 1/2 inch thick flanges. The turbo flange uses a donut gasket fit for best fitment. Includes factory hanger mounts and can be used with the stock cross bar or aftermarket ones. Downpipes are designed to give the car about 10 HP in the higher RPM while keeping the turbo spooled through the gears.
$284.99
RS*R Downpipe
The factory catalytic convertor assembly often chokes the exhaust system and prevents it from flowing at maximum velocity. In any turbocharged vehicle, significant increases in horsepower and torque can be found by simply eliminating this restriction in exhaust flow. RS-R has developed downpipes that provide the highest in performance, quality and craftsmanship for every turbocharged vehicle. Test results have shown that these down pipes in conjunction with the GT2 exhaust systems showed increased engine power by as much as 35 HP. Depending on your needs, RS-R offers these offroad downpipes in both polished stainless steel or ceramic coated applications.
RSR downpipe has a built in cat delete pipe which bolts directly to the stock or aftermarket catback exhaust. Pipe diameter is 3 inch with 1/2 inch thick flanges and donut gasket mount to turbo.
Picture is different then actual product. (references only)
$237.99
Prices do not include Shipping.
for questions or orders pm me or give me a call at 1.866.44.vivid ext 226
jacky
B&B Downpipe
$313.99
Espelir Downpipe
$169.99
Helix Downpipe
$304.99
Perrin Downpipe
$284.99
RS*R Downpipe
$237.99
jacky
Originally Posted by JT_EVO8
Hey, a few questions about the RS*R Downpipe w/ Cat delete:
Does it bolt up to the remainder of the factory exhaust?
Is it stainless steel?
Does it clear the stock braces?
Thanks!
JT
Thanks!
JT
yes
not sure, i tried calling rsr to find out but everyone is at sema. it should clear but at worst case you can always use 5mm washers to space the brace.
I have installed the Apexi 3" downpipe and fits perfectly with out any spacers and you don't have to buy another support bar.The RMR can't use the factory support bar.I have HKS 3" Hi Power Exhaust.Everything fits together really good.
