Want More Power?? Turn It up!
Old Jan 26, 2005 | 06:12 PM
LancerShop.com's Avatar
Gold Sponsor
Smile Want More Power?? Turn It up!
Hey Guys,
www.LancerShop.com is overstocked on Hallman boost controllers. We have reduced the prices and we are giving you free shipping.
Hallman Pro Boost Controller Kit $87.95 shipped
The brand new Hallman Pro Kit contains the newly designed Hallman Pro valve, the new standard by which manual boost controllers will be measured. It is machined of billet aluminum and stainless steel pieces, and incorporates new features not currently available on any other manual boost controller. No lock nut is utilized, and no tools are used to adjust your boost. Simply turn the adjustment knob and it stays put.
The adjustment knob cannot be lost or come out of the valve (that means perfect protection from overboosting due to adjustment knob loss - it cannot vibrate loose and come out). The Pro Kit includes the new Hallman Pro valve, 3 feet of vacuum line, mounting bracket, hardware packet, and complete installation instructions. This kit has all the installation hardware that is needed for most all turbo installs. Plus, it comes with a mounting clamp to hold the valve. Available in Red or Black.
Hallman Evolution Boost Controller Kit $154.95 shipped
The Hallman EVOLUTION Kit uses the same valve as the Pro Kit, and has the same features, but ALSO is integrated into a self-contained cockpit controller cable system.
It also contains a mounting bracket, 3 feet of hose, a hardware kit, and specific installation instructions. The cable is 72 inches in length. Available in Red or Black.
The self contained cable system allows you to adjust boost from inside your car! This new system makes it very easy to set initial desired boost level... there is no need to stop the car, pop the hood, adjust the valve, then drive to see what boost level it is set at (and possibly repeating this process several times). Sitting at a red light and want to turn up the boost? Its just an arm's reach away.
This unique cable system uses a sheathed cable that does not twist or bind. There is no "lateral torque". This means that you achieve consistent results when you turn your inside-the-cockpit adjustment knob. Just as precise as if you were turning a knob on the controller itself, as with the Hallman Pro or Hallman Pro RX kits.
Achieve the convenience of an electronic system (without the expense or complexity of electronics), with the reliability of a precise mechanical, manual boost control system!
All Hallman boost controllers on sale click here
Old Feb 1, 2005 | 10:06 AM
Gold Sponsor
Thanks for the orders guys, we still have tons more. We are swimming in hallman boost controllers at LancerShop.com
